Intercooler piping setup
Old Nov 12, 2006 | 09:41 AM
FCKing1995's Avatar
Rotary Slave
Im tryin to sort stuff out, for when I go FMIC. Im gonna be buying an ebay Intercooler, either SSautochrome or xsturbo. Now for piping, I will have a BNR Stage 3, a TO4B, which from what Ive heard has a 2'' outlet. I figure I will use 2.5 piping with a 2''-2.5'' stepup coupler. Then another at the IC which has 3'' inlet/outlet. From the IC to the Greddy Elbow, which from what Ive read is 2.75'', I will run 2.75'' pipe all the way. Does this sound like a sound setup, or should I run 3'' all the way from the IC to the Elbow to avoid using a reducer? This is my first home fabbed FMIC and wasnt sure if having those step-up elbows would cause any sort of turbulance. But I guess 2 small stepups is better than going straight from 2'' turbo outlet to a 3'' pipe, or am I wrong? Thanks
Old Nov 12, 2006 | 09:59 AM
Aaron Cake's Avatar
Engine, Not Motor
The easiest thing to do is probably to run 2.5" piping everywhere and use silicone adapters to make your size changes.
Old Nov 12, 2006 | 10:07 AM
FCKing1995's Avatar
Rotary Slave
Is that not going to hurt when I hit the IC and it steps down from 3'' back to 2.5''? Well I guess not too much. That will be the only bottleneck in the system, which wont be much I suppose. I might just do that.
Old Nov 12, 2006 | 10:31 AM
Aaron Cake's Avatar
Engine, Not Motor
No, it won't be a problem.
Old Nov 12, 2006 | 11:02 AM
rx7 FC TII's Avatar
Semper
let me know when you start this setup...i would like to help so i know what im doing when i do mine.....
Old Nov 12, 2006 | 11:03 AM
FCKing1995's Avatar
Rotary Slave
Will do, probably wont be till next month, or maybe just after christmas
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
yetter227
20
Sep 5, 2015 11:57 PM
