Gauge CLuster removal - Help please! (Pictures)
Old Nov 10, 2006 | 05:10 PM
lchaidez's Avatar
Caliente
So i was in the middle of removing my cluster. Ill be honest, i probably have the slightest clue on how to properly, if not just remove it from its place. Now i got stuck. How is it that i can get my hands into the back to either unplug or remove the cabling so that i can take it out.
Here is where i got stuck, im pretty sure theres the right way and the wrong way. n' im pretty sure i chose the wrong way haha. So some guidance would be great.
Im a beginner to installation and removal of components. Im just trying to learn for future referencing, and personal reference. Thanks!
Here are the pics.
Thanks in advance!
Old Nov 10, 2006 | 05:11 PM
lchaidez's Avatar
Caliente
now the purpose of me removing it, is because if you look closely i have a bad oil pressure gauge. I basically want to replace that with another one i purchased. thats identical. Thanks!
Old Nov 10, 2006 | 06:15 PM
lchaidez's Avatar
Caliente
Bump for the day
Old Nov 10, 2006 | 06:23 PM
Shaughn's Avatar
Burn Rubber Not Your Sole
remove the screws on the side of the housing
Old Nov 10, 2006 | 07:13 PM
mazdaverx713b's Avatar
Have RX-7, will restore
after that, reach up from behind the cluster and unplug the speedo cable. this should give you a couple of inches to pull the cluster out farther and remove the harness that are clipped to the back of the cluster. when you unplug the speedo cable, you must depress a clip on the side and it will pull straight out.
Molotovman's Avatar
Ban Peak
Reach Up from underneath, and disconnect the speedo cable, and the connector on the back.
You might also be able to tilt it and reach behind.
Its been a while since I've done it, but its pretty easy.
Old Nov 10, 2006 | 07:32 PM
drewl's Avatar
Flame Thrower
i've always been able to pull the left side of the cluster out and get my hand back there to remove the speedo cable.
Old Nov 10, 2006 | 08:09 PM
10AEturboII's Avatar
I didn't find it too easy to get the speedo cable out. What a PITA. You just have find a way to get your hands in there. A couple of skinned knuckles later and I had it out. Maybe I just have fat hands though. LOL
Old Nov 10, 2006 | 09:38 PM
lchaidez's Avatar
Caliente
lol... yea ill try it tomorrow morning. right now its night time so **** that ****. Anyways, thanks you guys. Ill see if i can pull it out a bit more. Ill keep you posted. Thanks!
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
