New Rx-7 owner
Old Nov 9, 2006 | 08:45 PM
eviljoel's Avatar
New Rx-7 owner
I just bought my first tuner car, a 1990 rx-7 convertible. Well i have a number of problems. Firsthand My gauges arent working 7.5 volt fuse is blown and i wondered why which lead me to my second problem. I look under to see the wirings i seen a lot of splicing, a lot of stray wires, and a whole lot of electrician's tape. I have a strange feeling that im going to have to rewire the whole thing. Now i start it and from the moment i start it to the moment i kill the engine there is a constant buzzing. Thats driving me crazy but i know something is wrong.
I also got a aftermarket exhaust from the cat back i occasionally get popping while idling but its not detonation.
As for work done on it the previous owner installed a body kit on it exhaust.
I have brand new bushings coming because i heard that 2 gens used plastic bushings and if thats true, then ill be willing to bet my last wrench on the fact some if not all of them are cracked. In response to that i ordered a hypermax 2 bushing kit.
If theres someone who is familiar with the electrical system on an rx-7 plz help me out!! thanks
Old Nov 9, 2006 | 08:50 PM
snowball's Avatar
I live in the lounge...
no plastic bushings lol, i would bet they are mostly dead though, something about 16 years...
Old Nov 9, 2006 | 08:55 PM
mekanikal's Avatar
ctrl + z my life
My meter fuse
is my excuse
to say my seven
is far from heaven
Old Nov 9, 2006 | 09:22 PM
Stanis's Avatar
*snaps fingers in rhythym*
Old Nov 9, 2006 | 10:24 PM
mnguy's Avatar
popping sound
im new to rotary and cars in general so theres a really good chance im wrong
and dont know what im talking about.
but i had the same problem on my old integra,
it was because the spark plugs were bad causing it to misfire,
after i changed the spark plugs the popping stopped.
maybe its the same on rotaries?
.....is it even possible for rotaries to misfire
Old Nov 10, 2006 | 06:45 AM
My5ABaby's Avatar
Rotaries confuse me
Yes.
Old Nov 10, 2006 | 09:17 PM
darktritium's Avatar
spazz!
Backfires are going to be music to your ears. (Maybe I'm just deafened by my car.) You may have some backfires when your car is warming up (~10-20 minutes), but after that, you shouldn't have any. You may get the occasional backfire during shifts if you wait too long between gears. (That's what happens when you have bad synchros, you have to f'in wait to shift.) I had an ***-ton of electrical-tape-wiring in my car when I got it. I've pulled the stereo, ripped (delicately) plastic panels off and snipped wires like you wouldn't believe. The idiot that had this car before me thought going to cheap route with stereo installation was the way to go. She's my rolling restoration project. Also, I'll say it before anyone else does: compression test. Check out the FAQ for links to the FSM (Factory Shop Manual) online and download ALL the PDFs. The FSM is the Bible of the RX-7. The compression test just gives you an idea of how the car's apex seals are, well, sealing. Too low of numbers and, since this is a tuner car, you should start with a rebuild and go from there. Just my 2.5 cents.
Old Nov 10, 2006 | 09:19 PM
spazz!
And do remember (as I have a very hard time remembering), these are not young cars. My car is even older than yours ('86), so you may have to replace all the hoses under the hood and rubber brake lines. (Which reminds me...)
Old Nov 11, 2006 | 12:22 AM
spookdog's Avatar
backfires are cool. People who dont like them should go back to a wussy piston engine..
Old Nov 13, 2006 | 04:52 PM
HAILERS's Avatar
HAILERS
Lack of coolant is causing the buzzer to go off. This fits in with your latest thread.
Old Nov 13, 2006 | 05:09 PM
smokie's Avatar
garageRE
for the back fire its normal for an rx7 to do that, thats just the way rotarys are built so dont wory about the back fire but everything else get that taking care of for the buzzing you may have a leak so try adding some coolant to your radiator and then see if you have a leak somewhere
Old Nov 13, 2006 | 06:16 PM
arghx's Avatar
rotorhead
ok this is why I made my comment in that other thread about spending extra to money to buy a car that hasn't been hacked up
Old Nov 13, 2006 | 06:39 PM
rrw's Avatar
rrw
Rapidly Running Wild
too bad good chassis are dying out
their going like hotcakes
Old Nov 16, 2006 | 04:10 PM
spazz!
Any word on your car? I love when people post questions and don't even bother to update us...
Old Nov 16, 2006 | 04:19 PM
bradenscreed's Avatar
shoulda seen the hack job on my moms old contour. whats up with people not caring much about their work...what the word... pride.
Old Nov 16, 2006 | 04:46 PM
spazz!
I hated how I'm having to undo things that should have never been done. TAKE CARE OF THE IMPORTANT STUFF FIRST! The guy that had this car before me didn't really think that rear bearings and brake rotors were above a stereo system with regards to priority. Moron. Anyway, now I have Powerslot rotors and Hawk HPS pads and I'm loving the combo. Not to mention everything else that I've been doing with this car.
Old Nov 16, 2006 | 05:31 PM
eviljoel's Avatar
ok yalls i started to fix it up i had several problems my most recent being the electrical system. im fixing it. i managed to service my gauges and they now work (cept the battery gauge) and have most of the interior back in place. i had a coolant problem but it is now rectified by burping the air from the system but i have to go back into the cooling system >.< to make a gasket for the thermostat because the gasket is leaking. ill be doing that tonight. as for it the popping i've been hearing in the exhaust is actually the air going from a narrow to wide pipes that are in the back.
Old Nov 16, 2006 | 11:57 PM
spazz!
Glad to hear it!
troym55
23
May 25, 2016 12:42 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
