setting tps
Old Nov 9, 2006 | 07:52 PM
rx7vadim's Avatar
setting tps
is there any difference setting tps with dmm or led lights?
Old Nov 10, 2006 | 07:19 AM
My5ABaby's Avatar
Rotaries confuse me
Some people get slightly different results. Best way I think is to set it to 1V at the ECU.
Old Nov 10, 2006 | 09:12 AM
Aaron Cake's Avatar
Engine, Not Motor
The lights don't work, the ohmmeter does.
Just make sure the car is fully warm first so that the cold start thermowax/cam assembly is not holding open the throttle.
Old Nov 10, 2006 | 09:14 AM
J-Rat's Avatar
Alcohol Fueled!
I personally have had much success with the light method, but whatever works!
Old Nov 10, 2006 | 09:17 AM
My5ABaby's Avatar
Rotaries confuse me
If you're an idiot like me and don't have the cold start thermowax/cam assembly, does the car still have to be warm?
Old Nov 10, 2006 | 09:23 AM
Chuck's Avatar
Actually, I use both. My primary method is by resistance. I set to 1K Ohm engine fully warmed up. Then I hook the twin lights up to see if I get a 1 light on condition. If I do, all is well. If I don't then I adjust until I do. Typically, the resistance is something different from 1 K Ohm but usually close. Then I always short the initial set connector (ground it if you're a S5) and adjust idle.
Old Nov 10, 2006 | 09:28 AM
Aaron Cake's Avatar
Engine, Not Motor
Nope.
Old Nov 10, 2006 | 09:30 AM
My5ABaby's Avatar
Rotaries confuse me
Nope.
Well that makes my life easier.
Old Nov 10, 2006 | 10:35 PM
rx7vadim's Avatar
thanx
befarrer
Microtech
Aug 22, 2015 05:52 PM
ncds_fc
Aug 15, 2015 10:06 AM
