shift up light
Old Nov 8, 2006 | 11:04 PM
ramz28's Avatar
shift up light
hey is this weird or can it be common, the shift up light does not go off ever and i tried the redline thing and i didnt here abuzz but it was for a very short time.
also weird feeling driving this car may sound like awhole lot of BS, but i had other ppl say the same thing, i redlined at 60mph in 2nd gear and felt this wierd funneling feeling, looking thru the windsheild only straight became visible everything else sorta fuzzed out normal? or am i crazy?
Old Nov 9, 2006 | 12:05 AM
bigdaddyp's Avatar
I am not sure I can answer all questions, but, if you are on the throttle hard, the shift light wont come on untill higher rpms, which I would assume that it could be messed up and not come on at all. Also, I have been to 60 in 2nd, and I dont remember anything other than, damn, this little old car can do 60 in 2nd.
Old Nov 9, 2006 | 12:33 AM
Icemark's Avatar
the shift up light comes on when you are less than 1/4 throttle and exceeding 2600 or more than half throttle and exceeding 4000 RPM.
It will not come on to tell you to shift at or near redline. It is a tool for getting the best fuel economy.
if the light is never coming on, either the bulb is bad, the connections to the back of the cluster are bad or the neutral safety wire is grounded or the 5th gear (over the top) switch is grounded.
Old Nov 9, 2006 | 01:19 AM
deagle50ae's Avatar
what are you on? You've been playing too much Need for Speed. if your vision is bluring at 60mph you NEED to see a doctor because your retina is detaching from the cone which can lead to perminant blindness.
Old Nov 9, 2006 | 05:04 AM
FCKing1995's Avatar
Rotary Slave
Thats good to know, I thought mine was messed up. Though it still is messed up. It will come on only at about 20-25% throttle, anything higher it wont, anything lower it wont
Old Nov 9, 2006 | 09:14 AM
ramz28's Avatar
ok well thanks for the shift up light stuff but im not the only 1 who felt that feeling even the passenger in the car felt it its was really wierd im not crazy i think. and i asked sumone ese to drive the car and tell me what they felt and said samething
Old Nov 9, 2006 | 09:19 AM
rx7 FC TII's Avatar
Semper
maybe your car is haunted by mr. wankel
Old Nov 9, 2006 | 10:04 AM
MmSadda's Avatar
amen
p.s. how do I add a quote to the board like FCKing and deagle have?
Old Nov 9, 2006 | 10:15 AM
SGesel's Avatar
Breakfast fortress
amen
Press the button that says quote at the bottom right of the post bro...............\/\/\/
Old Nov 9, 2006 | 10:21 AM
rx7 FC TII's Avatar
Semper
newbs.........jkman i was there too....back on topic my shift up light doesnt work during a drive but does while im turning the engine over to start.....what connection could be loose or grounded
Old Nov 9, 2006 | 12:30 PM
ramz28's Avatar
ok ignoring the sight problems, the car is great
Old Nov 9, 2006 | 12:52 PM
R_PROWESS's Avatar
F[x]3S ENG.
the sight problem.. the only thing i can think of is you have an exhaust leak.. fumes getting in the cabbin messing with your head lol
Old Nov 9, 2006 | 01:44 PM
ramz28's Avatar
well i do actualy have an exhuast leak
Old Nov 9, 2006 | 02:24 PM
lovintha7's Avatar
Suicidal Death Missile
Tunnel vision is caused by extreme acceleration. Doubtful in your case, but maybe possible under the certain conditions.
Old Nov 9, 2006 | 03:17 PM
ramz28's Avatar
hmmm well at leat ur not maken me feel crazy thanks
Old Nov 9, 2006 | 03:40 PM
My5ABaby's Avatar
Rotaries confuse me
In an Rx7...
Old Aug 2, 2019 | 12:37 PM
Hanime.Tv's Avatar
Originally Posted by My5ABaby
In an Rx7...
*Eurobeat intensify’s*
rx7shirley
Sep 2, 2015 02:11 PM
