what pullys
Old Mar 5, 2002 | 05:16 PM
bcty's Avatar
Boost This!
what pullys
i am going to remove all my un-needed stuff like the a/c power steering and i wanted to know what pullys i needed and other parts.. i want to remove the a/c , power steering , air pump , charcoal canister... and ideas?
Old Mar 5, 2002 | 08:54 PM
InfiniIIIREX's Avatar
Take out the carpeting and sound deadener, you can put in some lighter carpeting if you want. You'll be surprised how much weight will be in some unnecessary parts. Also get rid of the cats, not needed.
Old Mar 5, 2002 | 09:02 PM
bcty's Avatar
Boost This!
its going to be a show and go car... so i was just wondering what pullys will i need if i take that stuff out... maybe ill just buy a carpet kit from mariah..
Old Mar 5, 2002 | 09:41 PM
bcty's Avatar
Boost This!
bump
Old Mar 6, 2002 | 07:18 PM
bcty's Avatar
Boost This!
somebosy must know what pullys i need.. plz help i am doing this on this weekend! thanks
Old Mar 6, 2002 | 08:25 PM
NZConvertible's Avatar
I'm a boost creep...
Get a dual belt pulley for the alternator so the water pump still has two belts driving it after you remove the air pump. That's all you need.
Old Mar 6, 2002 | 08:39 PM
I wish I was driving!
Nanaimo, eh? Keep that charcoal canister. Illegal in bc to remove, and stupid as well. If you want a clean engine bay, put the canister elsewhere, like in the fender. I prefer to not smell gasoline at car shows, unless you have no gas in the tank. It's about the only emissions item I would keep.
As for pulleys, I'm not too sure what you are asking. Are you wondering what can all be removed stock, or for a recommendation aftermarket-wise? Stock, keep the rear two crank ones, all of the water pump ones (there is only one), and the alternator pulley. The other pulley's will come off with the attached item you are removing. The attached URL has a pic of Seth Wilson's car, with removed pulley's as I've said, and is using a duel alternator pulley on the top end.
http://www.2751engineering.com/intercoolerinstall_2.jpg
Sean Cathcart
Old Mar 7, 2002 | 11:37 AM
bcty's Avatar
Boost This!
thanks
Old Mar 7, 2002 | 04:48 PM
nathandarby67's Avatar
I could use one of those dual belt pullys for the water pump...where can I get one?
Old Mar 7, 2002 | 07:48 PM
Umm, your water upmp already has two pulleys on it. There is no need to add any more. To add a second belt, you need a dual ALTERNATOR pulley, and a removed air pump. Pulleys are available at most RX-7 shops, such as RX7.com and Racing Beat.
Sean
Old Mar 7, 2002 | 08:04 PM
Yeah, that was a typo...I meant alternator pully. I've already yanked the air pump a while back, so I just have the one belt. I'll check out those sites and see what I can find. Thanks!
Old Mar 7, 2002 | 11:31 PM
bcty's Avatar
Boost This!
just a quick Q... is it really easy to take off the power steering and a/c?? anybody know?
Old Mar 8, 2002 | 01:59 AM
Define *really easy*.
It is by no means a nightmare. Hardest part IMO is getting the bolts off the a/c compressor and such. You need tiny hands. Since you are removing the pumps and compressor, you can remove all the lines you want to make it easier.
For A/C, you take off the compressor and all the lines, up to the evaporator case (or is it condensor...hmmmm) in the cockpit (two connectors at the fire wall). I just threw some tape over the lines, I'll probably take out the core later.
As for P/S, remove all the lines leading up to the steering rack. Get some hose, any will do, and splice the two lines coming out of the rack together.
Remove the P/s and a/c fuses and you're done.
Sean
Enzo1944
Sep 6, 2015 08:57 AM
jhammerrx7
May 31, 2002 10:19 PM
