Sponsored by: CARiD
Blown apex or something else? Vid included
Old Nov 7, 2006 | 08:27 PM
Trybal's Avatar
what does this sound like to you?
the car is gutless, and is hard to take off unless at 4k or above..
http://www.youtube.com/watch?v=XD5kHv-_Ho0
i know, bad video and theres not much to go by, but i was told it was a blown rear seal.
Old Nov 8, 2006 | 12:52 PM
czseven's Avatar
czseven
Sounds like you lost a seal to me do a compression test.
Old Nov 8, 2006 | 05:04 PM
rx7rebirth's Avatar
Yea do a compresion test on it, its most likely is a seal
Old Nov 8, 2006 | 07:13 PM
C. Ludwig's Avatar
www.lms-efi.com
Yep. It's down a rotor for sure. Hope for a fouled plug or something. A compression test will confirm the worst case senario though.
Old Nov 8, 2006 | 09:09 PM
Trybal's Avatar
yeah, its got new plugs and its got spark, only other thing i can think of is a leaky injector but i doubt tahts it. Bad seal im sure, wish i had a mazda comp tester
Old Nov 8, 2006 | 11:17 PM
Tom93R1's Avatar
gross polluter
You can do a good enough job with a standard $25 compression tester. Just take out the insides of the schrader valve and look for 3 even pulses when cranking the motor. If you lost a seal it will be very obvious watching the gauge bounce.
Old Nov 9, 2006 | 12:34 AM
Trybal's Avatar
ohhhhh... learn something everyday. and i deff have one of those laying around
thanks for the help guys
whinin
Mar 30, 2019 07:53 PM
