launching
Old Mar 4, 2002 | 11:47 PM
lane_change's Avatar
It has begun
launching
I have only had my RX7 for a short while and have never raced it or even launched it hard. But, at what RPM do you guys that race launch from? I used to launch my GSX at around 4000-4500 rpm but it was AWD of course so I only would spin a little. With a RWD I don't want to waste my time spinning. I just need a reference to start from and then I will practice and find the right rpm for me. Thanks
Old Mar 5, 2002 | 12:11 AM
max. tt boost's Avatar
2800 - 3100 rpm. And never sidestep the clutch.
Just easy off it but quickly... giving it more gas as you go.
Good luck and may you get lotts of kills... jc
Old Mar 5, 2002 | 12:20 AM
It has begun
You slip the clutch on the RX7? I had to slip my GSX but that was so I did not wheel hop like a mad man.
Old Mar 5, 2002 | 12:35 AM
Why would u slip the clutch on a GSX? Its AWD u should be dropping that thing at like 5500-6krpm.
RX7's do tend to get a lot of wheel hop, so u have to sort of feather the clutch. If you it hopping then just back off and then give it some gas again.
Old Mar 5, 2002 | 12:38 AM
It has begun
At those RPM's I would spin like a mother-******. No slipping it worked the best for me in the GSX but the RX7 is a whole new game. I want to be able to run at least as fast as I could in my GSX. I ran a best of 12.2 in my GSX and I've seen a lot of people run faster than that here on the stock twins so that's my goal. Launching is just so I can cut a good light and have a nice 60 foot.
Old Mar 5, 2002 | 12:41 AM
In a gsx u wouldnt spin at 6k at all!
THe 7 takes some time to get used to, I usually rev to about 3 and then drop it to about 2500 and slip it out. It makes for a quick start. Just go out to a parking lot and "play with it"
You can hit low 12's ina rx7 fairly easily. All the bolt ons,some fuel and an IC should get u well into the 12's.
Old Mar 5, 2002 | 12:45 AM
It has begun
My GSX would light them up at 6k. I would spin through first and most of second. At the track, maybe not. But on the street where I typically raced, oh yeah. I still would out launch everyone and they would have to play catchup the rest of the way at the track. I only track raced it a few times, mostly street racing.
Old Mar 5, 2002 | 12:47 AM
really? thats weird. My friend does it all the time in the ******* rain and has traction at like 5k
Old Mar 5, 2002 | 12:51 AM
It has begun
In the rain? BS. Is he bone stock or something? When I first bought my GSX I thought I could race in the rain. I was way wrong, it gets pretty scary when your AWD decides it want to go sideways in the rain. When I was stock I could only chirp the tires but once I passed the 350 hp mark, it was all spinning from there. not as bad as my friends f-bodies but if I didb't slip the clutch out I think I would have lost some races where I pretty much won off the line and just held on.
Old Mar 5, 2002 | 01:15 AM
yy4u's Avatar
never sidestep the clutch? I thought that was the way to race any car, FD or otherwise, just find the right rpms such that you don't spin too much and sidestep. Is it better to:
a) feather it out starting at 4k rpm
b) sidestep around 2500-3k??
Anyone else agree that sidestepping is bad?
Old Mar 5, 2002 | 02:05 AM
LT1-7's Avatar
John
I had a GSX and it was pretty modified. I could not spin the tires unless I dropped the clutch at redline. Second gear I couldn't even if I tried. I think it would take a lot of power to spin in second gear in an AWD so I'm going to call BS on that. This guy I race with has a 1st gen GSX and he runs high 11's. He even told me that he could barely spin in 1st. He was trying real hard to spin just to get his turbo spooling but he could never do it enough.
Slip the clutch on your 7. I launched mine at about 3K if I can remember correctly. Then just give more gas as you take t he clutch out. That gives me my best 60' times. It'll kill your clutch especially if it's stock.
Old Mar 5, 2002 | 10:56 AM
CYM TKT's Avatar
hey, your car is on fire!
yeah I think slipping it is the best. for instance my clutch is pretty much toast (original w/65k), but I rev to 3k and slip it and I got a 2.106 60' time on street tires and ran a 13.3 @107.
Old Mar 5, 2002 | 10:57 AM
CYM TKT's Avatar
I know 2.1 isnt the best, but it is my personal best, and not too bad from what I have heard.
Old Mar 5, 2002 | 11:07 AM
NickSimcheck's Avatar
my friend has a 1st gen TSi AWD and he could chirp the tires bone stock at a 4500 launch. now he can do AWD burn outs the look on the bleach boys face when he sees all 4 tires roasting over is a sight to see. he runs 11.2-4's
Nick
no idea about 60ft times tho.. i'm gonna have to ask him on that one.
Old Mar 5, 2002 | 12:29 PM
It has begun
Well I could. spin them all. Ask my_jdm_rx7, he's been with me. I don't know why you couldn't spin them. ickSimCheck's friend could also so go figure. Mine was a 97 GSX with a Mutt Level 5 Turbo, Greddy FMIC, Web Cams, 660 injectors, Apex'i S-AFC, Greddy Profec B, ACT 2600, 3" Turbo back exhaust, and a lot of other mods. What did you have in yours? I never dynoed mine but I am guessing that I had around 400-450hp. Just guessing. If I could have launched better then I could probably broke into the 11's but I only went to the track a few times, mostly just Street Racing cause that's where an AWD really makes its mark I think.
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
matty
47
Oct 4, 2015 02:45 PM
Heedlessone
Sep 16, 2015 11:31 AM
