Tried FD chart insert.
Old Oct 23, 2006 | 09:06 PM
swif's Avatar
Almost back together
Question Tried FD chart insert.
I have tried to insert the off set for the rims that I am looking at buying. I am unable to do that.
I am looking at the enki RS+M in a 17 in. by 8 up front with off set of 35 or 45. For the rear I am looking at 17 in. by 8.5 with off set of 35
I like these rims for the look and tha weight of the rim. I there are other options let me know. The Enkis weight 15.8 lbs for front and the rear is around 17 lbs. or lower.
Old Oct 23, 2006 | 10:31 PM
swif's Avatar
Bump
Old Oct 23, 2006 | 10:52 PM
rynberg's Avatar
Pretty skinny to run on an FD...but the correct choices from those would be 17x8 +45 up front, 17x8.5 +35 at the rear. I would run 235/45 and 255/40 tires.
Old Oct 23, 2006 | 11:34 PM
swif's Avatar
The sizes that you gave me is what I was going to run. Will I have any problems with this set up? Also what else would you reccommend? What tire would you go with as well?
Thanks for your help.
Old Oct 24, 2006 | 05:02 PM
1st to 3rd's Avatar
The 17x8 does not come in the correct bolt pattern. The 8.5" has the correct 5x114.3 bolt pattern, but the +35 offset is too low for the front. You need to look for different rims.
Old Oct 24, 2006 | 05:42 PM
rynberg's Avatar
He is right. You need to look at different wheels. If you like Enkei, the RPM2s would be good in 17x8, +45, and 17x9 +40. Same tire sizes.
Old Oct 24, 2006 | 08:12 PM
swif's Avatar
I had called Enkei 2 days ago an d asked if they had the 17x 8 rim in the 5 x 114.3 and was told that they did. I then looked at the web a noticed that they did not have it listed. Tha is when I noticed that the off set was wrong.
I like the look of the rim as well as the weight. I want to stay around the same factory weight for the rims with 17s. I will be gooing to ss9 this weekend so I hope to see something I like.
I do like what fdnewbie has on there site for rims, but I want to know the weight. I send him an e-mail but no responce. Hopefully they well get back to me.
Old Oct 24, 2006 | 11:19 PM
rynberg's Avatar
def3, I just looked at the Japanese Enkei....they have those rims in the appropriate size/offset for the Japanese market. A good Enkei importer can get them for you probably.
17x8, +40 or +48 offset front, 17x8.5, +35 offset rear
Old Oct 25, 2006 | 01:07 AM
swif's Avatar
Thanks rynberg.
Now with this off set of +48 would I still be able to run a 235/45 tire up front? And for the rear would a 255/40 be to big?
Old Oct 25, 2006 | 01:14 AM
rynberg's Avatar
+48 is easier to run a 235/45 tire.....255/40 is the largest you should run on an 8.5....this is the Mazda OEM fitment for 99+ FDs...
Old Oct 25, 2006 | 01:45 AM
swif's Avatar
I will see if I can find some to import the rims for me in these sizes. I also am still waiting to find out the weight for the rz rims and the 02 type a rims.
I am looking at tires on try rack to see which brand to go with. I do want about 15k out of the tires with med to low road noise. I want a tire with great handling. No driving in the snow and driving when it rains in socal.
Hopefully I can get the wheel weight for the other rims because I am starting to like them more and more. I am thinking of goin with one of those. What do you all think of the rims I am trying to get? I only ask to get an idea for what people go for on there cars.
Thanks for you input
Old Oct 26, 2006 | 11:58 PM
swif's Avatar
Found the Enkei rims in the sizes I need. I am waiting to here form Fdnewbie about the weight for the RZ rims and the Spirit R Type A rims.
I will be going with the Advan Neova tires.
C. Ludwig
Jan 30, 2019 06:31 AM
The1Sun
Mar 18, 2018 11:08 PM
LUV94RX7
Rotary Car Performance
Oct 5, 2001 04:52 PM
LUV94RX7
Aug 21, 2001 12:15 PM
