Modify a KOYO
Old Oct 20, 2006 | 05:00 AM
Marcel Burkett's Avatar
Lightbulb Modify a KOYO
I currently run a single pass KOYO rad with a large Isuzu IC , my oil and water temps are great , especially on the highway , however they tend to rise a bit (95-98 deg C) when I'm in trafic for a while or when I stomp on it in short back to back bursts . I am soon going to be installing a Miezere 55gpm electric water pump (and maybe a thicker 4" intercooler) to keep temps under control , I'm also thinking about putting in two baffles (one in each tank) to convert my rad to a tripple pass , has anyone done anything like this ? , is it possible to do this without damaging the rad ?, anyone have any results to share ?
Old Oct 20, 2006 | 05:32 AM
AnthonyNYC's Avatar
Stay tuned...
I have a double pass radiator that I bought from summit racing for $185. It works excellent. In the NY heat in traffic on a 100deg day, I see temps no higher than 210 F with the AC on. I've been using these radiators for the past 6 years with no issues. It's also half the size of the normal koyo or fluidyne. You should have no issues but I would rather stick with the wider double pass than skinnier tripple passes.
Anthony
Old Oct 20, 2006 | 12:55 PM
Asleep's Avatar
7 Rx-7s since 1980
Anthony,
Which one / what size do you use from Summit?
Tony
Old Oct 20, 2006 | 06:15 PM
I wish I was driving!
http://www.stewartcomponents.com/tec...ech_Tips_5.htm
Old Oct 20, 2006 | 06:18 PM
Anthony
If I am to keep the stock radiator with the top inlet and bottom outlet (on a 3 RD gen ) , cross flow design it would have to be a 3 pass , If I was to do the 2 pass mod , both in and out would have to be on the same side .
Old Oct 22, 2006 | 08:41 PM
the_glass_man's Avatar
Will u do me a kindness?
Copy and paste from my other reply.
I just purchased a triple pass custom radiator instead of possibly butchering my Koyo. After I sold the Koyo and paid for my new hugh triple pass radiator I still had some money left over!
However I do believe it would be possible to modify your existing radiator. I decided not to chance it.
Koyo also maker a triple pass radiator called the N-Flow.
Old Oct 22, 2006 | 10:31 PM
ikari899's Avatar
engineer wanabe
yes its vert easy to changes around the end tanks on radiators, i have done it a couple of times to smaller fludyn radiators.
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
MidnightOwl
Sep 25, 2015 10:24 PM
