knocking noise from rear
Old Mar 3, 2002 | 06:18 PM
yes, I just started hearing this knocking noise coming from the right rear wheel, sus, or maybe a wheel bearing. Usually between shifts. I know i need shocks but this seems like something while the car in movement. I'm thinking its the wheel bearing, what to u guys think? thanks,, ANt
I bought the wheel bearings WoW there BIG.. ENCLOSED PIC
Old Mar 3, 2002 | 11:21 PM
Scott 89t2's Avatar
SOLD THE RX-7!
it's the front diff mount. 99% sure.
(the front mount on the rear diff, there is no diff in the front )
Old Mar 4, 2002 | 03:04 AM
maxcooper's Avatar
WWFSMD
Is this car an FC or FD? If it is an FC, the front diff mount is a good place to look, but I suspect it is an FD by your avatar (remember to specify next time, please).
There are lots of things that can clunk on the rear of the FD. They are:
- pillow ***** (http://www.maxcooper.com/rx7/how-to/...lls/index.html)
- toe links (get replacements from http://www.m2performance.com/)
- wheel bearings (it looks like you've got this one covered)
The rear wheel bearings look like a big PITA to replace. You have to remove the rear hub carrier (a.k.a. upright) and have them pressed out and the new ones pressed in. Also, I'd have a better idea of the bearing size if I just knew how tall that little figure ws.
-Max
Old Mar 4, 2002 | 02:08 PM
yeah it is an FD thanks....So yup, i will try to figure it out this wkend on whats going on with thos parts.. thanks
Yeah the bearings are just that.. PITA...And my lil man is about a pinkys lengh..hehe
Old Mar 4, 2002 | 04:17 PM
DamonB's Avatar
-Max
I did my right rear wheel bearing recently to replace a wheel stud. The bearing itself wasn't bad for the machine shop to press out of the hub carrier, but I couldn't get the axle to come out after removing the nut. Heating the inner bearing race with a torch and repeated heavy blows with a hammer finally got it loose.
Old Mar 4, 2002 | 07:07 PM
RotaryFanatic's Avatar
Newbie
I'm pretty sure my FD is doing the same thing as yours...please post what works if you figure it out. Thanks.
-Brandon
Old Mar 8, 2002 | 02:11 PM
TWyatt's Avatar
I have a similar noise in my FD and the High-Pro shop told me it was the rear lower control arm bushings.
Anyone know where I can get those bushings?
Old Mar 8, 2002 | 03:18 PM
DamonB's Avatar
Mazdatrix
Old May 21, 2019 | 02:52 AM
FD7KiD's Avatar
2SoonJr
what was the update?
msilvia
28
Apr 14, 2016 12:58 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Michael Mansour
Aug 18, 2015 03:13 AM
