Going for Worst Gas Mileage (mpg) on a stock port NA! (I bet i've got the record!)
Old Mar 3, 2002 | 01:35 AM
Manolis_D's Avatar
Wink Going for Worst Gas Mileage (mpg) on a stock port NA! (I bet i've got the record!)
Hey everyone!
It looks (based upon the position of the fuel gauge) like My friend is about to get close to 10 mpg in his 1991 NA (i've been driving it with him -- he doesn't have a license yet) That HAS to be a record or something!
Aside from the glory of having attained the worst gas mileage possible (just about) on a stock port 1991 NA motor, I was also wondering how it could have used so much gas! The only things I can think of are...
1). messing around with the cooling system (Car idling for ~2-3 hours total on the tank?)
2). 17 year old (me) having fun on backroads about 1/2 of the time (the rest was 'spirited' street driving)
Any ideas? I was probably shifting at about 5,000 during the 'spirited' driving, and maybe 3000 - 3500 during 'normal' driving
I've got you guys beat
Manolis
Old Mar 3, 2002 | 01:39 AM
Scott 89t2's Avatar
SOLD THE RX-7!
you had it running for 2-3 hours? that proabably used a bunch up...
Old Mar 3, 2002 | 01:43 AM
Manolis_D's Avatar
Yeah, but shouldn't I be getting like at least 15mpg (without the idling?)
That'd mean we used 33% of the fuel at idle -- yikes!
Old Mar 3, 2002 | 09:31 AM
z-man's Avatar
im was getting 10 mpg on an 86N/A. just found out that my o2 sensor is bad. hoping i will get better gas milage now since i replaced my o2 sensor.
Old Mar 3, 2002 | 11:41 AM
Scott 89t2's Avatar
SOLD THE RX-7!
o2 sensor can only change it by about 10%. so you might get 1mpg more after
SlithyTove's Avatar
Shoot, that's nothing. If I start and stop a lot I get about 9mpg in my 85 (stock). Of course if my car is warm ig actually gets pretty decent mileage, especially on the highway.
Old Mar 3, 2002 | 12:37 PM
niner's Avatar
A while back with my 89NA in the winter I was getting about 9-11mpg. That was with just normal driving. The engine was about to go though.
Old Mar 3, 2002 | 12:46 PM
ic3cold7's Avatar
Newbie
if you go above 4,000 rpms your 5 and 6 ports open causing an increase of 25 hp. this can be a major factor in your cars gas consumpion.
Old Mar 3, 2002 | 02:15 PM
CrazyDude's Avatar
The only reason MY car (the one he is talking about) is getting such low mileage is casue he drives it all the time and to just chug along in traffic he likes to be running 7000rpm in 1st gear instead of a resonable number in 3rd. Sonofabitch.
Old Mar 3, 2002 | 02:40 PM
Manolis_D's Avatar
Hehe... more like 4500
The coolant seals are also going we think -- could this affect mileage?
Old Mar 3, 2002 | 03:24 PM
supergoat's Avatar
Eggs are like fowl cheese
You are only measuring by needle position? There is no way to tell the gas mileage that way and be accurate. Go put fill up the car and run it down about 50 miles. Refil and devide 50(or however many miles you went) by the number of gallons you had to put back in. Voila!
Old Mar 3, 2002 | 03:28 PM
duffles's Avatar
hey man i was only getting 190 miles out of a tank full, but the engine's rear apex blew out then. now that it has a new engine, i'm running WAY better miliage. Sometimes compression hurts.
Old Mar 3, 2002 | 03:48 PM
darkwaveboi's Avatar
Need donor car in Fairfax
im getting ~200 miles per tank on an engine w/ 40,000 miles on it. of course i love to drive with it at least 4500 rpm
Old Mar 3, 2002 | 07:55 PM
Poindexter10thae's Avatar
AKA Poindexter
HAHAHAHAHHAHHA!!!!!!! you got a little bit to go home skillet!!! 7 MPG
1986 n/a
Weber 48mm carb conversion(jetted and tuned by yours truly)
RB header/PS
MSD 6A
Air pump in a dumpster
100-125 shot of Nitrous
ACV blockoff
Centerforce clutch
Perma Cool E-fan
Almost forgot to mention that this engine had blown Oil seals and would leave a cloud of blue smoke when you punched it.
Old Mar 3, 2002 | 09:49 PM
pp13bnos's Avatar
Pineapple Racer
You guys get terriable milage...my pp motor usualy got around 18-19mpg, with some serious spirited driving on occasions.
My n/a 90 gets around 25mpg, with 5-8 1st to 2nd gear 8k rpm runs. i just put on a Hi-6, so we'll see if it gets even better. CJ CJ
finky's Avatar
I emptied my tank at a short track day and that was 110 octane. DOH!
Old Mar 4, 2002 | 12:00 PM
My 86NA gets 18 in town and 24 on the road. This is with normal old geezer style driving.
This is also with a fresh overhaul where new rotor housings and lapped end housings were used. The injectors were also cleaned and checked out by RC engineering. I am running a Bonez down pipe in place of the cats as well. When the original engine was there about 20 to 21 (on the highway) was all I could manage. The engine was very low on compression when I bought the car.
Tylerx7fb
39
May 27, 2019 12:45 PM
12abridgeport
Aug 17, 2015 06:28 PM
Clacor
Aug 14, 2015 09:17 AM
