HELP... please with greddy fmic installation
Old Mar 3, 2002 | 12:43 AM
Rx-Revin's Avatar
Unhappy HELP... please with greddy fmic installation
ANY one how do you mount the radiator,the condensor and where does the p/s steering hose hook up at.
Thank You
Old Mar 3, 2002 | 01:48 PM
Sidestick's Avatar
If you got the complete kit, there should have been provided brackets for relocating the a/c condenser & radiator. The rad has to be stood up almost vertically, & the condenser has to be laid almost horizontally (front end tilted up slightly). I take it you didn't get any instructions, so it may be a bit tedoius figuring where each bracket goes. Also, when done, you have to mount one or two 10" aux electric fans on the condenser to maintain any kind of a/c when the car isn't moving.
As for the p/s line, did you get one with the kit? It should directly replace the stock one. Another couple of small brackets (more like aluminum strips) secures the line to the two rearmost bolts that hold on the plastic undertray.
Old Mar 3, 2002 | 04:06 PM
Rotary93's Avatar
Retired RX7 mechanic
Let me guess...You didnt get directions!
If you give me your email address, I can send you some pics of my install....
Old Mar 3, 2002 | 04:09 PM
DeNguyen's Avatar
i have the actual directions(w/pics) in japanese and english. i can mail them to you if you want em.
Old Mar 3, 2002 | 04:17 PM
Jason's Avatar
The one
For some reason Greddy does not pack instructions with their intercooler kits anymore.
Im going to put them in PDF format and post a link on the forum.
Jason
Old Feb 17, 2003 | 10:12 AM
coop's Avatar
Did that PDF file get posted? I am at the same stage with all the brackets...but I don't have AC any more...
(I know these are old threads but I have been looking at them all for the instructions.)
I don't have a fax machine...
Old Feb 17, 2003 | 10:22 AM
rxrotary2_7's Avatar
what are you having a problem with david? the instilation is actualy quite easy. there is a thread w/ direction for the 2row on here somewhere....i forget who did the writeup, i never bothered to read it, bu i know it helped others out.
Old Feb 17, 2003 | 10:28 AM
coop's Avatar
cool, I will try to find that one...
I just didn't know what all the brackets are for, and how the 'S' pipe replaces the original one...it seems that no matter how I rotate it, it just doesn't have the ends pointing in the correct directions...
Jason's Avatar
The one
Dave,
If you dont have the AC then you wont be using most of the brakets. The only ones you will use are for the radiator feet. They have holes in them. There is a good pic in the instructions.
Jason
Old Feb 17, 2003 | 10:34 AM
coop's Avatar
incase anyone is looking for this info... here is the link that seems to explain the install pretty well.
http://flathat.woodstream.net/RX7/Docs/Greddy_FMIC.html
Cheers
Old Feb 17, 2003 | 11:56 AM
Tomco78's Avatar
I never used the supplied P/S-line, made the whole thing fit with the stock one.
Old Feb 17, 2003 | 09:38 PM
coop's Avatar
I can't figure out how the P/S pipe replaces the factory one (yes I want to keep power steering)...anyone have a tip/picture?
Thanks
-D
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Clacor
Aug 14, 2015 09:17 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
