South RX-7 Forum Serving Texas, Oklahoma, Arkansas, Louisiana, Mississippi
Wolf 3D install and tuning in Houston?
Old Oct 13, 2006 | 11:01 PM
DrKillJoY's Avatar
Administrator
As the title says anyone in Houston ever setup or tuned a Wolf 3D here in Houston (or nearby)?
FYI - This is on a Turbo 2
Old Oct 14, 2006 | 09:12 AM
cewrx7r1's Avatar
Eye In The Sky
Keith,
Marcus use to do them.
Chuck
Old Oct 14, 2006 | 09:41 AM
DrKillJoY's Avatar
Administrator
Anyone else?
Old Oct 16, 2006 | 02:40 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Well if you cant find anyone to install it, I have more than enuff wiring under my belt.
Hay Keith check out my new toys i am selling
https://www.rx7club.com/showthread.p...2&page=1&pp=15
I my give one away at are Christmas Meeting for one of the Prizes.
Old Oct 16, 2006 | 12:24 PM
DrKillJoY's Avatar
Administrator
I have figured out that one of the key areas is to heat sheild the loom wires. Seems that many people overlook this crucial step and end up cooking the harness.
Old Oct 16, 2006 | 06:51 PM
twokrx7's Avatar
Need more sleep
I emailed spicracer, he used to run a Wolf on his third gen. If he can give me enough direction on the ins and outs of the ecu install I may be able to help you Keith, tuning it should be a snap. My only concern is the crank angle sensor calibration if it is not a bolton or plug and play affair.
Old Oct 16, 2006 | 07:10 PM
DrKillJoY's Avatar
Administrator
Awesome thanks for the help!
Old Oct 16, 2006 | 11:02 PM
Rx7_Nut13B's Avatar
And another thing is to make sure the Injector and Crank Angle sensor wires are sheilded.
Old Oct 17, 2006 | 08:38 PM
twokrx7's Avatar
Need more sleep
Keith,
I just got an email from Carlos so we should talk soon, perhaps I can even get a base map from him.
Kyle
Old Nov 7, 2007 | 01:53 AM
DrKillJoY's Avatar
Administrator
Kyle,
Did you ever get any info back from Carlos, I'd like to get started on this project and enjoy it a little before this beautiful weather goes away. Thanks, DKJ
Old Nov 7, 2007 | 02:23 AM
Rx7_Nut13B's Avatar
Hey Keith, I have that FD Igniter that you will need.
Also I have been looking for a Ignition amp for myself and i have learned that the MSD DIS-2/DIS-4 that you have will not work for a rotary. The fire events happen to fast for the box to spark the Leading and Trailing right after each other, what i am told is it needs at least 40 degrees between spark events.
I would just use the Stock coils and the FD igniter.
If you can find someone that can set it up i will finish the wiring for you. I still dont understand how to upload the map to it.
Also i modded a CAS for your car, the way that it is wired right now will work but isnt the best from what i have heard, so I have the CAS for it.
Also I will be off Wed and Thrusday i may try to drop by early thrusday to finish up the coil stuff. But i am kinda at a lost on the map loading.
Old Nov 7, 2007 | 05:56 AM
twokrx7's Avatar
Need more sleep
Carlos and I talked but it's been so long that I would have to contact him again. He is back from assignment so maybe we can get this going. PM me about all the details ... CAS, wolf version, etc
Claudio RX-7
Haltech Forum
Apr 23, 2019 02:50 PM
Jester's Toybox
Aug 18, 2015 06:03 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
