What Size Injectors And Setup
Old Oct 13, 2006 | 01:55 AM
robertwallace's Avatar
I own a 1995 fd3s and I have a street ported 13b engine with a to4r turbo. I am running a stock fuel injector setup but I have a greedy elbow with injector mounts in.
What size injectors should I use.
Were can I get a fuel rail and fittings to use on these injectors
Old Oct 13, 2006 | 08:47 AM
diabolical1's Avatar
if i understand what you're trying to do, then you're going for a 3-stage injector setup, right? well, i can't really help you with choosing the injector sizes, so hopefully someone else would chime in. with 550s and 850s as stock, maybe another set of 850s???
anyway, off the top of my head:
injectors: www.injectorsonline.com
fuel rail: www.atpturbo.com
fittings: www.summitracing.com
however, considering that you're in the UK, maybe you could try your regional forum to find sources more local to you.
hope this helps.
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
