Best tires for auto-x?
Old Oct 10, 2006 | 05:25 PM
tIIsleeper's Avatar
pp
What are the best possible tires that are dot legal and streetable for my tII that im auto crossing? Any suggestions would be great.
Old Oct 10, 2006 | 07:21 PM
theflatlander's Avatar
Dual Wielding DieGrinders
what are your terms of streetable?
Old Oct 10, 2006 | 07:55 PM
aznpoopy's Avatar
strike up the paean
azenis rt615
Old Oct 10, 2006 | 07:58 PM
rynberg's Avatar
Toyo RA-1 or Yoko Advan A048 or A032
Old Oct 10, 2006 | 08:00 PM
melicha8's Avatar
Mazdaspeeding
I don't think he's considering r compound tires though they are dot legal
Old Oct 10, 2006 | 08:49 PM
tIIsleeper's Avatar
pp
well. I just want a tire that is good for auto x that i will drive on the street. I was lookin at the advans and the 32's looked nice.
Old Oct 10, 2006 | 08:50 PM
mcfly's Avatar
kuhmo v710's
Old Oct 10, 2006 | 08:52 PM
Tanjo's Avatar
Royale with cheese
+1 on the falkens. Cheap and good.
Old Oct 10, 2006 | 09:37 PM
rynberg's Avatar
He did say streetable and DOT.....of which those qualify. The Falken RT-615 is pretty much unbeatable as a street tire for the money.
Originally Posted by icydude
kuhmo v710's
I guess you missed the part about STREETABLE.
Old Oct 10, 2006 | 10:26 PM
tIIsleeper's Avatar
pp
kk. ive decide ima go with the azenis rt 615.
215/45r17 or 215/40r17? Car is lowered about an inch. Which sidewall size should i order?
Does it really make a difference besides 5 bux?
Black91n/a's Avatar
If they're going to be your only tires then R's probably aren't a very smart choice. They'll wear out quickly, and more importantly, will heat cycle quickly, making the grip drop off considerably before they're worn out. The Azenis are the fastest street tires for autocross. Other good tires for autocross are the Hankook RS-2, the Kumho MX, the Advan AD07, and the BFG KD.
Old Oct 10, 2006 | 10:37 PM
tIIsleeper's Avatar
pp
I have a set of stock wheels that i can use for non auto-x days
aznpoopy's Avatar
strike up the paean
45 imo
Old Oct 10, 2006 | 10:54 PM
rynberg's Avatar
Uh yeah, it makes a difference!
The 215/45 17 is close to stock diameter (a little smaller, 225/45 17 would be closest).
Old Oct 10, 2006 | 11:11 PM
silentblu's Avatar
well i was told by a shop, that falkens suck now, or there was a bad batch or somthing
one of my friends runs falkens, don't know which one, and they pull to a certain direction when going forward, then the other direction going backwards. its not alignment either
Old Oct 10, 2006 | 11:14 PM
tIIsleeper's Avatar
pp
umm. I said sidewall. Not width.
Old Oct 10, 2006 | 11:40 PM
Black91n/a's Avatar
For autocross I'd get the 215/40/17, because it's smaller, gives lower CG for better grip, shorter gearing for better acceleration and shorter sidewall for better feel.
My dad's got a set of the new Azenis, they're great tires, awsome grip, not bad in the wet, acceptable wear. This is the first I've heard anyone badmouth the Azenis for anything other than heat causing them to go greasy, or the rapid wear.
Old Oct 10, 2006 | 11:41 PM
aznpoopy's Avatar
strike up the paean
sidewall number is expressed as percentage of width
rynberg is not wrong...
he is saying 225/45 is closer to stock diameter of stock wheel/tire package than a 215/45 which is a little smaller, and will thus make a typical car speedometer read faster than you are really going.
either way 45 imo is the way to go for daily duty
Old Oct 10, 2006 | 11:47 PM
rynberg's Avatar
Perhaps you should learn some tire basics..... start with the Tire Tech section at www.tirerack.com or some of the sticky threads at the top of this forum.
Old Oct 11, 2006 | 08:08 AM
tIIsleeper's Avatar
pp
ya. ill do that, sorry
rx7jocke
72
Jun 17, 2016 03:48 AM
