(ELECTRICAL) Considering running another fusebox/distribution box.
Old Oct 8, 2006 | 11:57 PM
Dan_s_young's Avatar
Turbo widebody FB
Hey guys,
Here is my thinking, im going to have ALOT of accessories in my RX-7 that are going to be wired in.
Example:
redoing the power window wiring
CD player
New headlight wiring
LM-1
Greddy profec B spec II
microtech LT10s
5 autometer cobalt gauges
J and S knock sensor
Anyways im going to be relocating my battery into the passenger side bin. Im thinking it would be nice to have another fuse box in the bin, so I could properly run power to all the accessories and have them fused. Anyone have any suggestions or opinions on doing this? I would like to keep everything under its own fuse to keep the setup simplicity, if you start running 5+ accessories off a single lead you are just asking for problems and diagnosis will be a nightmare...
Has anyone else done this before and is there a fusebox that you guys suggest on using?
Thanks
Dan_s_young
Old Oct 9, 2006 | 12:30 AM
1badFB's Avatar
GSSL-SE
I have thought about the same thing myself. While you can get plenty of inexpensive little isolated power distribution blocks and fuse holders, the best bet would be to dish out a bit more cash and get something quality from painless performance. They do specialize in full wiring kits, but if you either have a good look on their website or give them a call Im sure they will have something ideal for you. I had a makeshift power distribution block for my stereo and alarm and accessories, but I could have been happier with it and in my opinion you dont want to mess around with anything electrical (I burnt my finger prety darn bad with an unfused wire once) If I were doing it again, Id either retrofit a fusebox from another vehicle in, or get something from painless.
Old Oct 9, 2006 | 12:37 AM
Rx Seven's Avatar
Can You Wankel?
Why dont you use multiple FC fuse boxs there are 5 spaces on each.
Old Oct 9, 2006 | 02:15 AM
Directfreak's Avatar
I am a Jeeper Now.
i have one from painless wiring in my car for the same reason you want. The stock wiring in my car is 100% intact and uncut because of it.
Old Oct 9, 2006 | 10:26 AM
Turbo widebody FB
The reason is that I would rather have 1 fusebox for all the accessories rather than 2-3. If I need to do any electrical diagnosis in the future I would like to make it as simple as possible.
I found a painless wiring aux fuse box for like 50 dollars, but it is only 4 spade. I dunno I am actually kinda considering running another fusebox like what we have under the dash. That what I will have multiple hook ups for accessories, and keep most of the fuses together so they can be checked easily.
Maybe I should request the fusebox from someone parting their car out...
Old Oct 9, 2006 | 10:41 AM
Aaron Cake's Avatar
Engine, Not Motor
I run two AUX fuse boxes in my FC, and do so in all standalone installations. It's the only sane way to do things.
http://www.waytekwire.com has a good selection of quality Bussman fuse boxes. You can get them with ground planes as well.
Here's what I did:
Old Oct 9, 2006 | 12:31 PM
John64's Avatar
What?
Aaron, very nice, but you cannot put anything near that because its not covered. I think he want one that can mount and be covered.
Old Oct 9, 2006 | 05:52 PM
trochoid's Avatar
Old Fart Young at Heart
For simplicity, I would find an FC in the boneyard, take the underhood fuse block and mounting bracket. Clip the wiretails from the bottom as long as you can. Iirc, one fuse is for the block itself and the other 4 are outputs.
Old Oct 9, 2006 | 06:11 PM
Sgt Fox's Avatar
Stigulus Moderatorai
Here is what I did:
Disregard the epoxy on the cover, I stepped on it.....
You can buy these online from Centech Electric
http://www.centechwire.com/catalog/index.html
its the FB-6 $12.95
http://www.centechwire.com/catalog/panels/fb4.shtml
Old Oct 9, 2006 | 06:56 PM
John64's Avatar
What?
Sgt. not to step on your feet, but thats not too weather tight and to just use spade connectors is a no no. Solder them on and use heat shrink!
Old Oct 9, 2006 | 07:45 PM
trochoid's Avatar
Heat shrink rocks. I have a friend that works at a Ford dealership. The heat shink I get from him has an inner coating that melts and gives a weather tight seal. Much better than the cheap crap from the parts stores.
Old Oct 9, 2006 | 09:30 PM
Turbo widebody FB
I would buy that fuse box panel right there but there is no shipping to Canada... I guess I should maybe go with another FC fuse box...
Old Oct 10, 2006 | 12:01 AM
Sgt Fox's Avatar
email them or phone them.... centech will ship to canada.
Old Oct 10, 2006 | 12:05 AM
Sgt Fox's Avatar
Well in the spade connectors is dielectric grease.
As for the spade connectors, a properly crimped connector is just as good as a solder joint. What do you think all the plugs in your car are?
And as far as water goes.... hardly any water gets up there, and even if it does it wont matter. I've sprayed a hose on it many times before.
If you wonder where I'm getting my info from, i am an electrical engineer....
Old Oct 10, 2006 | 12:31 AM
I am a Jeeper Now.
This one is pretty nice..
http://www.centechwire.com/catalog/panels/ap1.shtml
Old Oct 10, 2006 | 05:04 AM
John64's Avatar
What?
That is nice!
Old Oct 10, 2006 | 10:00 AM
MattG's Avatar
MattG FTW!!!!!
Whoa, that is hella nice! I think I may get me one of those. At 50 bucks its not a bad price!
I would use that in stead of all the inline fuses that I planned on using when I redo my Fuel pump, E-Fan, Headlights, etc etc.
Old Oct 10, 2006 | 10:24 AM
Hades12's Avatar
Burning Oil-Grinding 3rd
That is some nice stuff.
Bookmarked.
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
