Coolant Flow Path
Old Oct 9, 2006 | 11:18 AM
Marcel Burkett's Avatar
Question Coolant Flow Path
Anyone have a diagram of the coolant flow path through the 13B REW engine ?
Old Oct 9, 2006 | 05:22 PM
Anybody ? , I'm getting ready to install my Meziere EWP and I want to get it right the first time , I've done a lot of searches and have found a lot of stuff , everyone has an opinion , so here is what I decided , I'm using the Mieziere instead of the Davies Craig 'cause I just cant be comfortable with a "plastic" pump in the heat of the rotarys bonnet ! , I'm keeping my water pump housing and replacing the pump with a block off plate , so my alternator will stay where it is. I'm going to use a stock thermostat with a pair of 5mm holes drilled in it (?) to provide the bypass back to the radiator ,the original bypass port is blocked already using the same "block off " disc off an old thermostat , retaining the hole in the midle so that there is a small flow through the bypass port(( and thermostat ) when the motor is cold , during normal operation the temperature would be regulated by the thermostat , closing when it gets cold but still providing a flow , since some flow IS required to allow everything to function properly, LEMME know what U think !!
Old Oct 11, 2006 | 03:31 PM
KevinK2's Avatar
http://www.autosportracetech.com/RX-7/coolingsystem.htm
Old Oct 12, 2006 | 06:25 PM
thanks alot
squirrels
Sep 1, 2024 09:52 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
