cheapest compression tester for rotaries, where to buy?
Old Oct 9, 2006 | 07:13 AM
20bfd3s's Avatar
%subj
thanks...
Old Oct 9, 2006 | 08:00 AM
My5ABaby's Avatar
Rotaries confuse me
Autzone...
Old Oct 9, 2006 | 08:22 AM
20bfd3s's Avatar
you mean autozone.com ?
rotary comp tester is a bit special tool, as you know... that web shop definetly could not have it.
we will need to know all three chambers comp. ratio while measuring each spark plug.
the only one that i found so far is that mazdatrix sells for $850
http://www.mazdatrix.com/toolmisc.htm
but are there any cheaper solutions available on the market?
Old Oct 9, 2006 | 08:47 AM
C. Ludwig's Avatar
www.lms-efi.com
None available. You can make you own for about $200. All you need is a pressure transducer and a datalogger.
Old Oct 9, 2006 | 06:52 PM
AGreen's Avatar
Trunk Ornament
The cheapest? It's easy but not as completely accurate as a digital gauge.
This would entail getting a cheap compression tester and removing the schrader valve from the end of it. The schrader keeps the pressure in the gauge, showing only the highest reading. Removing it allows each face of the rotor to show how much compression it's achieving by itself. Spin the engine and watch for the pulses. A good reading will be over 85 psi each pulse. If it's one good pulse followed by two low readings, it's an apex seal. If it's 2 good pulses followed by a single low, then you've got a burned side seal.
On my engine, after rebuilding it, the readings showed 100 psi on all three sides, both rotors.
Old Oct 9, 2006 | 08:17 PM
user 893453465346's Avatar
Red Pill Dealer
Can't you just use a regular Autozone one? Hold the Schrader valve in to read faces and let it go to get total?
Old Oct 13, 2006 | 12:36 PM
Carzy Driver's Avatar
Law Breaker
$10 compressor tester from Harbor Freight. just remove the schrader valve and you're good to go.
http://www.harborfreight.com/cpi/cta...emnumber=92697 $4.99 special.
Old Oct 16, 2006 | 03:36 PM
Turbo23's Avatar
Panda Bear
^ basically same style I use. Just look for 3 even bounces of the needle.
Old Oct 16, 2006 | 05:17 PM
Black91n/a's Avatar
Get a regular compression tester that doesn't hold the reading then video tape it while it's testing. That's cheap and easy datalogging right there. Just be sure to set the camera for a fast frame rate if possible.
cristoDathird
28
May 30, 2019 08:47 PM
astrum
24
Nov 15, 2017 08:44 AM
elfking
Aug 19, 2015 09:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
