Wheel/Tire fitment
Old Oct 7, 2006 | 11:29 PM
Dee18701's Avatar
Wheel/Tire fitment
I know...I Know... There is a Official Wheel and Tire Fitment Thread but ive gone thru about 15 pages out of 112 or so and I still didnt get all the info I need. All I need to know is if I get 17x7 rims with a 40 offset all the way around what size tire would best fit and would they stick out at all...... I know guys youve been thru this before so im sorry....
its a 87 GXL
Old Oct 7, 2006 | 11:57 PM
stevej88na's Avatar
Strength and Honor
Use the graphic here to calculate a good tire size. Take your current wheels and tires as a comparison so that the final tire you decide on will be about the same overall diameter, otherwise your speedometer will be off, among other things. You can see just how different by dividing your old tire diameter by your new tire diameter; that's the fraction of your old tach reading that your new tire diameter will yield.
i.e. if your current setup has a 24" diameter, and what you want has a 25" diameter, at 100mph your new tach reading will be:
100mph * 24" / 25" = 96mph
So long story short, check some tire options and try to make the new diameter as close to the old one as possible. I'm guessing you'll go with 205 width on a 7" wheel, so see how 40, 45, 50, and 55 series tires calculate vs. your current wheels and tires. (start with 50)
Old Oct 8, 2006 | 12:29 AM
Dee18701's Avatar
OK i jus did some more research how does a 215/50-17 tire sound? Any clearance problems? Will they stick out from the fenders?
Old Oct 8, 2006 | 12:53 AM
stevej88na's Avatar
Strength and Honor
Sounds promising, though I think people usually go 7.5" with 215s
Old Oct 8, 2006 | 12:59 AM
Dee18701's Avatar
ya but the rims i really want dont come in 7.5 but will there ba any problems at all with the 215/50s?
Old Oct 8, 2006 | 06:55 AM
crazyboosta's Avatar
A stock rim is 7" +40. So why would it stick out??
http://www.fc3spro.com/TECH/MODS/RT/rims.htm
Old Oct 8, 2006 | 11:15 AM
Sideways7's Avatar
I run 225's with no problems on my stock 7" rims.
Old Oct 8, 2006 | 07:32 PM
I am running 215/45 R17 with no rubbing problems at all! However, I still feel like 18" wheels would look at lot better!
Old Oct 8, 2006 | 09:03 PM
spot_skater's Avatar
The Cause of Death
A 50 sidewall is too tall, IMO. On my old 17's I ran a 215/45ZR17, and it didn't throw off the speedo by much, if at all. The difference in size between those and the stockers (diameter) is ~1/2", probably less. This isn't speculation, I just looked at the two sets side by side in my basement.
This was on a 17x7" wheel btw. With a +35 offset... I ran spacers.
I run 225's on my stock size TII wheels (not TII wheels, though) as well, and there are no problems. With Eibach Pro-kit and Tokico blues.
James
Old Oct 8, 2006 | 09:41 PM
jgrts20's Avatar
Who are you?
Im running 17x7 with 40 offset. Im running 215-45-17 in the front and 225-45-17 in the rear.
Old Oct 9, 2006 | 01:57 AM
ARD T2's Avatar
Depending on your suspension you can run up to a 225/45/17 on that 7.0" wheel. It will look a little bulgy but is doable. Regardless that wheel is gonna look extremely sunken in the rear. It's a FWD wheel fitment. Would not do the FC much justic imho.
you'd be better off getting a 7.0" +15 or +20 to make it look right. There are plenty of cheap staggered wheels out there. You can easily run a 8" wide wheel up front as well.
Rishie
renjiv2
57
Jan 25, 2024 03:34 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Turblown
Sep 30, 2015 05:58 PM
