Rtek and boost controller, is porting my wastegate still needed?
Old Oct 7, 2006 | 02:19 AM
mike_rudy's Avatar
I am putting the rtek 1.7 chip on my 1987 TII. I also have an electronic boost controller that i have yet to install. I have full 3" exhaust and a k&n filter. Will i still need to port my wastegate? I am looking to run around 8psi for the street and 12psi at the track.
Old Oct 7, 2006 | 02:24 AM
snowball's Avatar
I live in the lounge...
you will need to port.
no boost controller can make your boost go lower than it would with no controller.
Old Oct 7, 2006 | 02:27 AM
Phantomhp's Avatar
Yes, you will still need to do a port on the stock wastgate.
I run 10-12 psi with an AVC-R. I was getting boost creep with just a straight through 3" exhaust. Now I see none after porting.
Either port now or rebuild later.
Mike
Old Oct 7, 2006 | 02:38 AM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
yes port. I have a simluar setup. and i was getting boost creep bad until i ported
cristoDathird
28
May 30, 2019 08:47 PM
