Broad question, but need some input
Old Mar 1, 2002 | 11:18 PM
pp13bnos's Avatar
Pineapple Racer
Within a year, i plan on going single. What i would like is to make 350-400rwhp on pump gas (Is this safely possiable?) What i would like is a general idea of a turbo that can make that much hp, and if possiable, have a fairly quick spool. Can you make 350-400rhwp on a stock port engine below 15psi?
Also, how much $$ am i going to be spending on this and a haltech, bigger injectors, etc.
I know these are broad questions, but i'd just like to get an idea of what i'm looking at spending, for my addiction.
Thanks, CJ
Old Mar 2, 2002 | 03:31 AM
maxcooper's Avatar
WWFSMD
The XS T04E kit is a good choice for your goals. The A'PEXi RX6 meets your goals, too, but the turbo is not rebuildable in the U.S. (expensive when you pop the motor) and I have had some trouble with the A'PEXi wastegate in road racing use on my car, so I recommend the XS kit over the A'PEXi one.
You'll also need tons of other stuff, as you seem to be aware. How much you spend on that other stuff is often listed and debated, so you might do well by searching for "injectors" or something and see what turns up. My opinion is that it costs at least $6,000 to get the big parts you need to go single (including the turbo kit) and usually $10,000+ to get it all sorted out (including lots of little $50-$400 incidental parts) and tuned ($500+) as you want it to be. Most people seem to need at least one rebuild in the process, which adds another $5,000-ish on top of that. That assumes you are starting with a stock car.
You'll hear many more opinions on this, but the people who are going through (like me) or have been through this process are usually the ones that estimate on the high end of the scale. Single turbos aren't cheap.
Go fast parts are like crack, I am hooked, and that is just the way it goes.
-Max
Old Mar 2, 2002 | 04:25 AM
LUV94RX7's Avatar
Oldie, but Goodie
Ken 57 years young,
'94 white, pep, red leather,
mods: Street port and polished stage II, upgraded coolant seals,
Hurley 3mm racing apex seals, XS T04E Turbo Kit,
GReddy SMIC, Pettit ss resonated MP, Pettit ss cat-back,
RP Racing fuel pump, Aquamist 2s water injection kit,
under pulley kit(no air pump), Pettit short shifter kit, boost gauge,
AEM EMS, 3-bar MAP Sensor, Profec B(12-2?psi), 1600cc injectors,
LaBreck bushings, Evans coolant.
<http://nopistons.com/luv94rx7.html>
Old Mar 2, 2002 | 08:43 AM
crispeed's Avatar
'Tuna'
Re: Broad question, but need some input
Thanks, CJ
Turbo--> 60-1 with a .70 compressor housing with either a .81 or .96 open or .84 or 1.0 divided turbine housing using a P or Q-trim turbine wheel!
Power--> Presently tuning an 88 TII with a stock motor that's using the above turbo and power so far checks in at 340RWHP at 12.5psi.
crispeed
87TII
9.20@150mph
_Tones_
May 25, 2021 05:37 AM
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
The1Sun
Sep 15, 2015 04:45 PM
Nosferatu
Sep 5, 2015 02:13 PM
