Sponsored by: CARiD
New motor and car wont start
Old Oct 4, 2006 | 08:28 PM
STLDriftFC's Avatar
hey guys my name is Tim and i just had the motor swapped out in my 89 turbo2. we put in the same kind of motor but it was a jdm one and it was proubly a diffrent year. well we got everything hooked up and when we turn the key it sounds preety good but wont start. we checked everything we could think of but still nothing.the compression seems to be fine and there is definatly a spark and it smells like its getting fuel. it seemed to get closer the more times we tried to start it but were not positive. any ideas would be great
Old Oct 4, 2006 | 09:23 PM
KansasCityREPU's Avatar
Out In the Barn
I've had good success with using starting fluid on motors like this.
Old Oct 4, 2006 | 11:19 PM
trochoid's Avatar
Old Fart Young at Heart
Pull your plugs and see if they are wet with fuel or fouled. If either, clean and dry them well, I like to beadblast mine. Then squirt some motor oil in the housings, turn the engine over backwards by hand to spread the oil around, reinstall plugs and try again.
Old Oct 5, 2006 | 02:58 PM
STLDriftFC's Avatar
ok so we found out that the fuel injectors arnt spraying. the injectors them self are good because they came from the old motor. so any ideas? maby bad wires but wouldnt that involve pretty much pulling the motor to check
Old Oct 5, 2006 | 03:32 PM
myfc3s's Avatar
That's what she said...
I say your flooded, remove plugs and see if they are wet.
Old Oct 6, 2006 | 10:20 AM
STLDriftFC's Avatar
im not flodded if you read what i put above i said that i have a bad wire or a bad ground to the injectors
gtcd
30
Aug 19, 2015 02:44 AM
ashleymiche
Aug 14, 2015 12:59 PM
