Racing Helmet Suggestion
Old Sep 30, 2006 | 11:51 AM
ohayou88's Avatar
So can anyone suggest a cheap Open face helmet for around 250 and under. Need one for autox
Old Sep 30, 2006 | 11:56 AM
finky's Avatar
Check out G force. They sell through Jegs.com and Summit.com
I found my open face for $160
http://www.jegs.com/webapp/wcs/store...tegoryId=63501
Old Sep 30, 2006 | 11:57 AM
Turbo23's Avatar
Panda Bear
http://www.racerwholesale.com/produc...roducts_id=559
Old Sep 30, 2006 | 12:02 PM
photopaintball's Avatar
http://www.apexperformance.net/cartg...t.asp?scat=274
Old Sep 30, 2006 | 07:15 PM
ohayou88's Avatar
I got an idea of a few i want.. So how does helmet fitting work??
Old Oct 1, 2006 | 08:24 AM
EProdRx7's Avatar
www.saferacer.com
Old Oct 1, 2006 | 11:05 AM
Jabberwocky's Avatar
For autocrossing i's suggest a cheapie M2000 motorcycle helmet. If you go to track days and such later on, you'll want a more expensive full face helmet.
Old Oct 1, 2006 | 12:12 PM
HedgeHog's Avatar
Rotary Poseur
Get a Pyrotect (http://www.pyrotect.com/home.php), they have M/SA2005 out and are very cheap. I was told they are made by the same manufacturer as Bell.
Black91n/a's Avatar
Almost all track days or driving schools require SA rated helmets, so if you think you'll want to go to one in the future, don't waste your money on an M rated helmet, unless you want 2 helmets.
Old Oct 1, 2006 | 12:17 PM
tims's Avatar
My suggestion is to find the best fitting helmet you can afford. Pyrotect and G-force have very good price points. But ultimately cost should not be the deciding factor, because the fit is the most important. If you don't have a local shop to try the helmet contact the companies when purchasing and find out what their return policy is. I know Pyrotect will let you return the helmet if you don't like the fit. I would also suggest the close face helmet as well as an SA rated model. Personally I use a Bell Vortex FA currently but I have used the Simpson Voyager as well.
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
