How much horspower and boost can the stock o.em. clutch and flywheel on the 3rd gen
Old Mar 1, 2002 | 02:11 AM
kam's Avatar
kam
I was wondering what the maximum horsepower the rx7's stock o.em. clutch and fly wheel can handle, i have only down pipe, knn drop in filter in stock box, and downpipe. So the horespower i have is around 290, please tell me how much horspower the stock clutch and flywheel on the third gen can handle.
Old Mar 1, 2002 | 02:32 AM
thatoneguy's Avatar
Well, I had intake, dp, mp, cb, ecu@14psi. I'm estimating that I had close to 400hp by the trap speed I was getting in the quarter mile. The clutch slipped and doesn't grab quick enough. My guess is that the stock clutch is good for about 330-350hp.
Old Mar 1, 2002 | 04:22 AM
DeNguyen's Avatar
stock flywheel will hold more power than you can make...
Old Mar 1, 2002 | 06:37 AM
ttpowerd's Avatar
HARRRRRRRRR
I have 288 rwhp and 251 rwtq and my stcok clutch is slipping. I have heard 300 fwhp but I don't know for sure.
Old Mar 1, 2002 | 09:16 AM
GEB's Avatar
GEB
I purchased my car back in 98, completely bone stock.
The clutch was dead when I got it. I wound up purchasing the Bonez street clutch assembly. I believe they stated that it was 15% more grip than the OEM unit. I kept the stock flywheel at the time.
Shortly thereafter, I add the DP/Cat back/Intake and ECU. The Bonez clutch began slipping almost immediately. It was basically my stupidity for not putting up more money for the "street-comp" unit (Which I think is an ACT knock-off anyway). The part that will fail is the pressure plate. The OEM clutch disk can support a lot more power than you would realize. As for the flywheel, the OEM unit could probably handle as much power as you could throw at it! (big heavy bastard!).
Anyways....The morale of the story is: If you plan on doing any type of upgrades in the future, just go ahead and get the "street-comp" or "heavy duty" clutch assembly (which ever manufacturer).
I now have the ACT Heavy Duty pressure plate with the stock clutch disk. I also added the 8.5lb flywheel. I put down about 300rwhp and this setup definitely rocks!
Good Luck
GEB.
Old Mar 1, 2002 | 10:01 AM
rotary-tt's Avatar
2 babies - no back seats
I was told up to 400 hp by Racing Beat. Perhaps that is too optimistic. I am around 300hp with an new stock clutch. No problems.
Old Mar 1, 2002 | 03:20 PM
pp13bnos's Avatar
Pineapple Racer
My car has 45-46k on the stock clutch and even some 18psi runs (boost controler problems) it held just fine. Look at my sig for my upgrades. CJ
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Clacor
Aug 14, 2015 09:17 AM
