OIL in the gas?
Old Feb 28, 2002 | 07:21 PM
damn hippies
Question OIL in the gas?
Ive heard of people putting oil in the gas to help lube the rotors but i dont know if its true, what kind of oil,and how much . Does anyone do this and would it be a good idea for me to?
Old Feb 28, 2002 | 07:32 PM
kundo's Avatar
yeah its called Marvels Mystery oil. You put about 4oz to 10 gallons of gas. you can use it on any car. Also most people say it stops the little smoke that comes out in the morning starts. You can buy it at any autoparts store for about 3 to 4 dollars
Old Feb 28, 2002 | 07:33 PM
damn hippies
Alright thanx for the info, they way i heard it made it sound like a 2cycle mix or something, i know what your talking about ive seen the stuff.
Old Feb 28, 2002 | 07:44 PM
RETed's Avatar
It's actually called "pre-mix".&nbsp Those with intact OMP systems are recommended to run 400:1 ratios.&nbsp Those without OMP systems can run a little bit more between 100:1 to 150:1 ratios.&nbsp Pre-mix is added to gasoline when filling every tank.
-Ted
Old Feb 28, 2002 | 07:56 PM
damn hippies
whats this OMP thing im not followng ya
Old Feb 28, 2002 | 08:00 PM
RETed's Avatar
OMP = oil metering pump
-Ted
Old Feb 28, 2002 | 08:01 PM
damn hippies
Im not sure i got a 87TII im not sure if it has one or not were would it be located
Old Feb 28, 2002 | 08:04 PM
RETed's Avatar
ALL rotaries from Mazda have them.&nbsp I'd bet you still have yours.
-Ted
Old Feb 28, 2002 | 09:14 PM
CNYRX7tech's Avatar
Exclamation Syracuse RX7 Mechanic
StepDaddy,
I work at a repair shop in N.Syracuse call me Mon. thur Fri. 8am to 5:30pm 315-458-8381. I can help you with you RX. I am currently replacing my engine which was modded to a great level ( Singer of a band I manage cooked the engine) ( now he owns a gsl-se) and rebluiding the transmission.
Old Mar 1, 2002 | 01:27 AM
fcturbo2's Avatar
OMP is located in the front of the engine. Front cover to be exact. If you have an 87 you have a mechanical OMP.
Microtech
30
Apr 23, 2016 06:37 PM
R7rexy
19
Sep 2, 2015 10:24 AM
smikels
Aug 18, 2015 01:26 PM
