Thumping Noise???
Old Sep 22, 2006 | 12:01 AM
novaboy009's Avatar
DD Rex
Thumping Noise???
I'm getting a thumping noise coming from my back passenger side wheel. If I hit a pot hole it usually thumps once on the way down and once on the way back up. Shock? Wheel bearing? Gas tank hitting something (replaced fairly recently, can't remember if it thumped before)? Exhaust? Take a wild guess before I tear the rear end apart to change the bearings.
Kev
Old Sep 22, 2006 | 12:05 AM
Rogue_Wulff's Avatar
Too old to act my age
Shock bushing possibly. Axle bearings usually make noise at certain RPM/speed, not just on bumps.
Old Sep 22, 2006 | 12:06 AM
SAH-RX7's Avatar
I doubt it the wheel bearings, my experience has been that you will get a constant thumping/clicking that changes frequency with the wheel rotation speed. Sounds more shock or spring related to me..
Old Sep 22, 2006 | 12:54 AM
GavinJuice's Avatar
Leave A Message
swaybar endlinks?
Old Sep 22, 2006 | 10:27 AM
novaboy009's Avatar
DD Rex
Shocks were replaced 3 months ago, end link bushings were also replaced.....
Kev
Old Sep 22, 2006 | 12:04 PM
gypsyvk's Avatar
Make sure that something wasn't left loose when everything was replaced. You may want to check the exhaust mounts while your under there.
Old Sep 22, 2006 | 12:22 PM
ratboy's Avatar
Yup check your lower rear shock mounts. Replaced mine and a few weeks later one was loose enough to remove by hand!!! I guess I missed that one with the torque wrench!
Old Sep 22, 2006 | 01:58 PM
perfect_circle's Avatar
check the exhaust. at first i was thinking maybe you were hitting the bumpstops, but you said it thumps on thw way back up...hrmm
Old Sep 22, 2006 | 02:42 PM
novaboy009's Avatar
DD Rex
It's kind of an odd thump. It doesn't even have to be much of a pot hole, just a little unevenness in the road and the back of the car repetively thumps. Even road, no thumping.
Kev
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
Linda_Lovelace
Sep 18, 2015 10:04 PM
