exhuast system race pipe
Old Sep 21, 2006 | 06:23 PM
turbo-111's Avatar
10 pounds sounds so nasty
is any one running a race pipe on the fd? i just want to know does it sound good or sound like $h!t ? and how restcrictive is the stock exuast ? can i expect the average 7-15 hp gain as in most turbo'ed cars ??
Old Sep 22, 2006 | 10:28 AM
C. Ludwig's Avatar
www.lms-efi.com
If you do nothing other than remove the cats from the FD you'll most likely end up needing a new engine in short order. There is power to be had but the problem is that when you remove that restriction from the exhaust, assuming the turbos and their control system is healthy, the boost level will rise. The stock ECU is not capable of reliably supporting boost levels much over stock. It runs lean and POP. Go to the 3rd gen section, search, and read. All the info you need on the proper way to mod the car is there.
Th0m4s
Feb 26, 2019 02:04 AM
