Newly rebuilt engine blown--what happened?
Old Sep 19, 2006 | 09:34 PM
RotaryTom's Avatar
I had my engine rebuilt last spring by a rotary specialist here in the Seattle area. The water seals had failed, presumably from old age. The car had only 78k original miles and no mods at all.
I've been taking my rotaries to this particular tech since I bought my first RX-7 in 1982. The guy has always taken good care of me and been very cool to deal with.
I was driving my car on the freeway last thursday and suddenly the engine started to run rough and lacked power. No noise, no "Bang", nothing to indicate a catastrophic failure. I was very close to my mechanic's shop so I limped it in. I was figuring a popped vacuum hose or something simple. Figured I'd be on the road again in a flash. My tech took one listen to the engine cranking and said that it didn't sound good at all.
I spoke with him today--tuesday, and he told me the apex seals went on the front rotor and that the engine is 10 times worse than before he rebuilt it last spring.
The only issue that I'd had with the car since the rebuild was an occasional rough idle and a very occasional random knocking at freeway speeds in 5th at about 2800 rpm. It only happened about 6 times in the 5 months since the rebuild and I wasn't at all sure that I was hearing predetonation. And I couldn't make it happen on demand to demonstrate it to my tech.
The only mod that we did with the rebuild was add a Pettit downpipe. All else is stock including the ecu. Any thoughts about what might have happened? I'm really puzzled. I take good care of my car--never abusive, just fun driving.
The other issue is my mechanic. The engine rebuild came with a one year warranty. He's pretty upset about having to eat an engine rebuild and all the parts that now need to be replaced. I don't blame him and I don't want to screw him over. At the same time I can't afford to pay for something that I don't believe that I caused.
Yes, this sucks! Any thoughts and advice are greatly appreciated.
Old Sep 19, 2006 | 09:42 PM
VegasFD's Avatar
Wishin I Still Had The FD
Don't worry about how the mechanic "feels" about this. That's why there are warranties- to protect you in cases like this. Just let him rebuild it and hope it doesn't happen again.
Old Sep 19, 2006 | 10:34 PM
c00lduke's Avatar
perhaps one of the injectors failed
Old Sep 20, 2006 | 07:25 AM
When he performed the engine job, did he recommend having your injectors cleaned/flowtested?
Also, I hope that he replaced all four of your injector plastic fuel diffusers. If he reused those, one could have broken off and fallen into your motor. They get very brittle with age and heat, and the last time I heard a story like yours that was indeed the case
Old Sep 20, 2006 | 07:35 AM
dubulup's Avatar
development
knocking at 2800 rpm is a serious issue...
what rpm were you at when the motor let go.
have your mechanic inspect the twins...I'm almost sure the turbine blades are chewed up. That might come out of your pocket though.
Old Sep 21, 2006 | 03:09 AM
RotaryTom's Avatar
I don't know for sure what the rpms were, but it was likely in the 2500 range as I was doing about 65 in 5th. There was no sign on knocking on that trip at all.
It's really disappointing to have all this happen. I bought the car in 2002 with 28k on it and it ran great with no problems until the water seals started leaking and I had to have the engine rebuilt. Man these are expensive cars to own... I sure love mine though...
Old Sep 21, 2006 | 07:17 AM
^^Are you going to investigate the issue with the fuel diffusers? I'll bet that is your problem.
Old Sep 21, 2006 | 07:58 AM
Improved FD's Avatar
vegasFD has the best avatar ever
Old Sep 21, 2006 | 08:07 AM
the list of potential wear/maintenance items that can lead to catastrophic failure on these engines is amazingly long
should we all drive a Ford Cobra?
nah....
Old Sep 21, 2006 | 08:21 AM
Well, supposedly you can just remove the diffusers altogether, thus eliminating a failure point. Once you get rid of the original/10-12 yr old ones, you don't much much to worry about. With our modded cars, you're going to be cracking apart the motor sooner than that anyway
Old Sep 21, 2006 | 11:43 AM
RotaryTom's Avatar
I *am* going to check out the injector issue. Seems like I can't afford not to. Is it possible for our cars to predetonate with no audible indication? I'm wondering if I had a big problem with it for an extended period of time with no outward signs and it weakened the seal(s) over time until they failed. I understand that any knocking is bad, but can it take place with no symptoms?
Thx for the help!
Old Sep 22, 2006 | 11:10 AM
RotaryTom's Avatar
Anyone else?
Old Sep 22, 2006 | 12:19 PM
amp's Avatar
amp
old yella
warranties serves a purpose..
and regardless of service tenure.. not everyone bats a thousand..
Old Sep 22, 2006 | 01:43 PM
G's 3rd Gen's Avatar
As Rich stated it sounds like some kind of injector issue. Intermittent prior symptoms + a front rotor gone. New motor w/ 80k injectors is taking a chance. Flow test them when you pull . Then have them cleaned.Good luck
Old Sep 22, 2006 | 02:01 PM
RCCAZ 1's Avatar
If the injectors check out as being good you might want to also consider replacing your engine wiring harnesses as long as the mechanic has the motor out. Could be a broken or chaffed wire causing intermittent problems.
Ciclovnz
Oct 18, 2015 03:04 PM
ncds_fc
Aug 15, 2015 10:06 AM
