Manifold porting methods
Old Sep 18, 2006 | 12:51 PM
rx7man13b's Avatar
Where can I send my lower intake manifold to get ported (gasket matched?)to match the motor. What kind of bit would I neeed to do it myself?
Old Sep 18, 2006 | 12:53 PM
Aaron Cake's Avatar
Engine, Not Motor
Don't know where you can send it besides a hot rod shop or performance shop. There's nothing really hard about gasket matching the manifolds...
You can easily do it with a Dremel tool and a number of rotary bits. I prefer rotary files as they love to eat aluminium. Then finish off with a sanding disk to get a smooth transition.
Old Sep 18, 2006 | 01:01 PM
rx7man13b's Avatar
I think Ill try it. Thanks
Old Sep 18, 2006 | 02:35 PM
rx7man13b's Avatar
Before I do this, is it worth doing? What kind of gains should I expect? Doesnt bigger ports mean less low end? Anyone done this on a S5 na? any info is appreciated
Old Sep 18, 2006 | 08:15 PM
scrip7's Avatar
Rotary Gearhead
You might get differing opinions on this, mine is that you should keep from making the port sizes much larger than they are now, you can lose a certain amount of velocity from making the ports larger. You can have noticeable improvement by smoothing out casting flash (ridges) and gasket-matching the port openings.
Old Sep 19, 2006 | 08:56 AM
Aaron Cake's Avatar
Engine, Not Motor
It's not worth doing unless you already have the manifolds removed and are very bored.
Ian_D
Oct 14, 2015 12:31 PM
mulcryant
Sep 9, 2015 05:24 PM
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
