Question: Ignition Breakup??
Old Sep 17, 2006 | 03:33 PM
JCurry's Avatar
Shpee
Thumbs down Question: Ignition Breakup??
What will make your car have ignition breakup. I recently saw this video and he said it had ignition breakup, and thats EXACTLY how my car sounds in higher rpms.... Would the timing being off cause this or do i have a weak coil or wires or something.... My plugs, and wires are new so i dont think thats the prob, but i cant get my timing right cause my idle wants to stay above 1200 rpms. soo wat will cause this???
http://video.google.com/videoplay?do...62026996&hl=en Here is the Vid of the car that sounds just like mine....
Thanx
Old Sep 17, 2006 | 05:54 PM
Wankel7's Avatar
Haven't we ALL heard this
Set your timing so it is correct. The idle issue is another issue.
I would rather have correct timing and a high idle. Than incorrect timing and a good idle.
Unless all you do is idle the car :P
Old Sep 17, 2006 | 07:51 PM
JCurry's Avatar
Shpee
yes i kno i need to set the timing but you cant unless your idle is low, but my idle issue is because of my bac valve so I can fix it.... but will incorrect timing cause ignition breakup?
Old Sep 17, 2006 | 08:23 PM
Mankdrake 2661's Avatar
Mazda goes MMMMMMMM
I would like to know also.
Old Sep 17, 2006 | 09:53 PM
Wankel7's Avatar
Yes, incorrect timing will cause break up .
And you can set your timing at what ever rpm floats your boat.
James
Old Sep 17, 2006 | 09:56 PM
JCurry's Avatar
Shpee
yeah but the ecu adjusts your timing automaticly after 1000 rpms right? so if you adjust it that high your gonna be incorrect???
Old Sep 18, 2006 | 12:41 AM
Wankel7's Avatar
I think that is where / why you jumper the initial set connector.
Do you have a hayes manual?
Old Sep 18, 2006 | 01:01 AM
JCurry's Avatar
Shpee
so when u jumper that it wont automaticly adjust your timing???
I checked the haynes manual and it didnt say anything about jumpering the initial set coupler....
musker
Oct 1, 2015 05:58 PM
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
