Microtech LT8s: Wiring up the Fans for an FD?
Old Sep 16, 2006 | 11:53 PM
str8ryd's Avatar
Nearing Completion...
Exclamation LT8s: Wiring up the Fans for an FD?
Hey,
I was wondering if anyone could help me out with this? I'm having a lot of trouble figuring out how to wire up the fans to run properly with a Microtech LT8s. As of now I can get the fans to work, but they're not controlled through the computer so I don't think they'll turn on when needed. Any help is appreciated. PLEASE let me know. Thanks.
Rizwan
Old Sep 17, 2006 | 09:39 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't know about the FD fans specifically, but it's pretty easy...
Get a relay of at least 30A. Connect the common contact (normally pin 30) to a fused 12V source from your battery. Fuse it for 30A. Connect the normally open contact (pin 87) to the + side of your fan. Ground the other side of the fan to a good ground. Connec one side of the coil (either pin 85 or 86) to a 12V IGN signal. Connect the other side of the coil to the Microtech's white wire.
That is the hardware setup. In software, go to screen 29 and set "AuxFAN_ON" to the temperature at which you want the fan to come on.
Old Sep 19, 2006 | 02:39 PM
str8ryd's Avatar
^Thanks! That was actually really helpful. I'm pretty sure we got the fan situation figured out now.
Blastfastrotary
Sep 11, 2015 12:26 AM
The1Sun
Sep 7, 2015 10:21 PM
