rebuilding rear brake calipers
Old Sep 16, 2006 | 01:13 PM
slo's Avatar
slo
registered user
For anyone who has ever rebuilt rear brake calipers. The Kits I have come with 2 packs of grease one orange and one red?
What is each for, I have read the FSM and it doesn't specify.
If it helps the orange is about a tea spoon, the red about half that.
Thank you
Old Sep 16, 2006 | 10:00 PM
slo's Avatar
slo
registered user
some one has to know the awnser to this. I got the rebuild kits from mazdatrix and they didn't even know.
Old Sep 17, 2006 | 01:56 AM
Gen2n3's Avatar
Super Moderator
Veteran: Navy
I rebuilt my calipers all around at once but I don't seem to remember the different color grease. I believe it is for the rubber seal to set in the race, which one to use I wouldn't know (or remember).
Old Sep 17, 2006 | 04:50 AM
twister7's Avatar
Have no idea,, got my kits from napa,,there was no grease in mine,,u just need some thing to protect the o-ring/seal when u put them together I used Vaseline same thing witch is used to protect lip seal when rebuilding automatic transmissions,,only thing i can think of is maybe one is grease and one is a sealer for the out side dust boot(2 help hold the boot in the caliper)!!
Old Dec 3, 2012 | 10:26 AM
RXeckless's Avatar
Rotorless
I'm in the process of rebuilding both the front and rears on my FD. Fronts are done and was searching info about the rears.
Just a FYI in case someone else needs this info
Grease colours
Orange Grease: Bearings, adjusting bolt, strut and piston boot
Pink Grease:Piston seal
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
