problem with rear lights
Old Sep 15, 2006 | 03:17 PM
rx7racerboy2003's Avatar
my running light wont come on brake lights and blinkers work so do headlights but rear running lights wont work. someone said it might be the switch but i changed that out and it still doesn't work. Anyone help desperatly needed and fast daily driver cant drive it at night it sucks.
Old Sep 15, 2006 | 03:57 PM
jeremy's Avatar
male stripper
there is a fuse that covers the interior, tail and side marker lights.
Old Sep 15, 2006 | 04:14 PM
thank
the fuse used to keep blowing but i put in the new unit and the fuse isn't blowing yet the light still aren't coming on
Old Sep 15, 2006 | 04:29 PM
classicauto's Avatar
Crash Auto?Fix Auto.
umm have you checked the bulbs/sockets?
Old Sep 15, 2006 | 05:14 PM
already put new lights in i started there but nothin
Old Sep 15, 2006 | 05:32 PM
stylEmon's Avatar
FC since 99
Have you changed the wiring harness? I blew two harnesses and one switch intil I rebuilt the curuit using IceMarks technique. You gotta add a 30A relay to the curcuit. Takes about an hour to do the repair.
Old Sep 15, 2006 | 05:52 PM
na i haven't changed the harness what all do i need to do to do icemarks way
Old Sep 15, 2006 | 06:00 PM
stylEmon's Avatar
FC since 99
https://www.rx7club.com/showthread.p...adlight+switch
theres the link. I didnt soulder becasue I bought the cheap *** battery powered soulder-er that sux a big one.
I crimpped wires together and used the metal connectors for the actual relay.
If you take the harness out for the headlight switch, you might be able to see a burnt out connection. Check the prongs on both sides of the connection. It was obvious on mine.
fastsaab
Aug 19, 2015 11:42 AM
