NEW TII wiring harness??
Old Sep 14, 2006 | 04:45 PM
crickifur's Avatar
Does anybody know where I can buy a NEW engine wiring harness for an 87 TII?? The one that came with my new engine has some pretty whipped terminals and I figure its probably easier and smarter to just buy a new one to stop later problems from happening. Thanks for the help, it's GREATLY appreciated!
Old Sep 14, 2006 | 04:49 PM
13bturbofc's Avatar
mmm doritos
im not sure where but they cost lke 600$ 4 a new one but u should check out ebay or the for sale section in this forum
Old Sep 14, 2006 | 05:31 PM
crickifur's Avatar
Ive been checking both areas including the other forum with no real luck. If there is one, its in the same shape as the one I have...
Old Sep 14, 2006 | 05:36 PM
daten's Avatar
You could make one from scratch.
Or maybe get one designed for a standalone like haltech and modify it back to fit the stock ECU plug?
Old Sep 14, 2006 | 08:26 PM
rrw's Avatar
rrw
Rapidly Running Wild
see if you could order one from a mazda dealership but that =like 1000
Old Sep 14, 2006 | 08:33 PM
Sideways7's Avatar
Yep, any new harness will be super expensive. You might as well get a used standalone with harness for the money you would spend.
Old Sep 15, 2006 | 02:45 AM
crickifur's Avatar
Well... On that note, what do you guys recommend?? FCON, Mega squirt...
Old Sep 15, 2006 | 04:48 PM
13bturbofc's Avatar
mmm doritos
microtech
Old Sep 15, 2006 | 07:17 PM
SpAm@FC's Avatar
do it like me...
get a used harness (mine was 80.000km old), strip it COMPLETELY, give you some time, soldering tools and new isolation tape....
looks like new
Old Sep 15, 2006 | 08:32 PM
Digi7ech's Avatar
I break Diff mounts
I just did that to one harness I have as a back up specifically for my car.
I just got a S4 low impedance harness and am about to go over it.
I've found some nast wires and plan to use my harness scraps to fix them. BY the end I shoudl have a harness which will function like a new one plus a few goodies like extra ground points which all connect.
I'm adding a Passenger fende r to boost sensor to Engine block ground. Along with a ECU ground to chassis point. I'm going to sell it so if someone's interested I could make it specifically for them.
Here are pics of the one I did as back up for my conversion.
and all the useless wires I pulled for emissions and stuff
Old Sep 15, 2006 | 08:38 PM
Japan2LA's Avatar
S4 TII NEW Harness is NLA.. Gone forever...Mazda discontinued the part.. Find a used oone and patch it up or go standalone
82streetracer
Aug 23, 2015 09:28 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
