TII turbo ?
A frend of mine is constantly having ptoblems with his twins and has decided that he wants to do a single turbo conversion yesterday ! , problem is , he's broke so he's looking for a cheaper route (until better can be done) , so heres the question , anybody try a turbo and manifold from a series 5 second gen on their third gen ? , how did it work , were there any fitment problems ? , whate performance ? and did you do any additional supporting mods ?
It's drastic, but it can be done.
The turbo is capable of making anywhere from 200 to 250 at the wheels, with boost under 15psi.
If you're looking for a compressor map, there is no official compressor map easily available.
The turbo is very close to what a Garrett S-trim compressor map looks like.
Clearance should not be a problem, since the 13B-REW LIM hugs closer to the engine.
Oil supply should be the same, since both 13BT and 13B-REW uses the same oil supply point on the front iron.
You will most likely need to fab an oil drain line, since the 13B-REW front cover drain is slightly different.
Coolant lines to the turbo need to be addressed also.
-Ted
-Ted
There are hybrid fc turbos running 350-400rwhp.
but FDs can do up there w/ a ported motor and stock twins even! not alone the fd hybrids. but fc turbo is half the price
Trending Topics
a friends fd had a hybrid s5 turbo on his fd, the fit is very factory, its 90% bolt on. power with the hybrid is about the same as an fd with a dp and non sequential, its not that fast, but it is simple, it fits, and its cheap
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
