How to check Radio Power Antena
Old Sep 13, 2006 | 12:09 PM
winter39's Avatar
Got Rotors?
Is there a simple way to "BENCH CHECK" the power antena motor assembly if it is already removed from the car? I am looking at buying a used one and would like to do a quick check before I buy it to make sure it goes up and down.
Thanks
Old Sep 14, 2006 | 03:20 AM
NZConvertible's Avatar
I'm a boost creep...
Put 12V to the L/W, B/G and LG wires, and ground the antenna body. Ground the L/Y wire and the antenna will go up. Remove it and it'll go back down.
Wiring diagrams are your friend...
Old Sep 15, 2006 | 01:55 AM
winter39's Avatar
Got Rotors?
Thanks, I will try this out!
Old Sep 15, 2006 | 02:07 AM
Sideways7's Avatar
Damn, I might have sold a good antenna for 10 bucks then. From the wiring diagram I saw you only needed power on 2 wires. Oh well.
Queppa
Nov 18, 2024 03:47 AM
