NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Looking for a rotary specialist in NE!
Old Sep 13, 2006 | 10:22 AM
foreignracer's Avatar
I love twins!
Exclamation Looking for a rotary specialist in NE!
Does anyone know where I can find a rotary specialist in the New England area? I have heard of a guy named Barry down in Massachusetts that is very good, so if anyone knows of him or knows him personally, please get me contact information or I will give my information. I heard he has a 9 second yellow 3rd gen that he races at New England Dragway. I have been working on my 7 all summer and finally got fed up and took it to Mazda. They are now baffled as to what to do since the car is modded.
So, if someone has some knowledge that they can impart on me, I would greatly appreciate it.
-Corey
Old Sep 13, 2006 | 10:40 AM
treceb's Avatar
any links that talk bout your problem?
i know kahren is in CT. also ask willub and company or zumspeed theyre from the MA area.
Old Sep 13, 2006 | 12:44 PM
FDTT19's Avatar
Give Jesse Martello a call at (860)978- 2687. He's in Somers, Ct. He did a great job on my car and he really knows it inside and out, whether you're modified or not. He's actually got my car at the moment but I should have it back this weekend.
- Matt
Old Sep 13, 2006 | 09:34 PM
IRPerformance's Avatar
Sponsor
What are you looking to have done? Shoot me a pm.
Old Sep 13, 2006 | 10:41 PM
ZumSpeedRX-7's Avatar
rotary amuse
+1 for Jesse Martello in Somers, Ct. he has my car right now as well, and there is no one else in the area i'd trust it with. (matt, the car's lookin good. i saw it when i dropped mine off. definatly comin together nicely.)
Old Sep 14, 2006 | 08:08 AM
FDTT19's Avatar
I don't mean to high jack the thread but thanks for the compliment Rick, your car's looking sweet with the carbon fiber hood and side skirts.
Old Sep 14, 2006 | 10:49 AM
rotary amuse
Thanks Matt.
Foreign Racer- I sent you a PM
Old Sep 14, 2006 | 12:28 PM
I love twins!
Thanks for the input guys. I will give Jesse a call soon.
Old Sep 14, 2006 | 02:25 PM
willub and company's Avatar
Pobody's Nerfect
+2 for Jesse. what is the problem. if you didnt want to go all the way to CT i could definitly look at it for you.
Old Sep 14, 2006 | 04:58 PM
I love twins!
Here is the basic problem in a nutshell.....sort of:
Well, its quite the long story. I put a Pettit Racing stage 2 ported motor in it this summer. Here are the mods:
-downpipe
-midpipe
-catback
-Pettit intake
-underdrive pulley
-12lb flywheel
I am running stock turbos, injectors, and fuel rail. I have a Pettit ECU. I went to start the car and blew the slave cyclinder out. So I got fed up. I took it to Mazda cause they actually have a rotary tech from back in the day that worked on 7's. He replaced the slave, vaccum lines and the T2 coil. It runs with the Pettit ECU but it is really rich and won't idle. It also coughs above 3000 rpm. So, with the stock ECU, it will idle and run with no smoke. It still chockes above 3000 rpm. I know that I can not run the stock computer with the upgrades but the Pettit does not perfom properly. So, I would assume I need to go with the Apexi Power FC if I can not use the Pettit ECU. Anyway, I do not have enough knowledge to trouble shoot this and get it running properly.
Old Sep 15, 2006 | 04:39 PM
Pobody's Nerfect
what do you mean by "coughs"? is it pulling any engine codes with the stock ecu hooked up?
Old Sep 15, 2006 | 06:08 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I can get you BPR's number later if you need, my friend goes there often and he will have it
what do you need done? where you located in NH?
Old Sep 15, 2006 | 11:44 PM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
for one you can run the stuff you have off the stock ecu, not advisable for aggresive driving.
and it sounds like your TPS is out of whack. Have you spec'ed it? Try putting a digital multimeter on it (black and green wires (from the back part of the harness)) and test it warm. If the car it comes back about or lower than 1 ohm. then adjust the screw to the left of the tps(turbo 2 only) once that is set. Take the butterfly on the TB and slowly open it. If it overloads or goes above 6 ohms then your tps is shot which could cause hesitations as well as a funky idle.
Mark
Old Sep 15, 2006 | 11:45 PM
http://fc3spro.com/TECH/HOWTO/TPS/tps.html
here is a great how to.
Old Sep 16, 2006 | 09:55 AM
I love twins!
I am in Manch-Vegas. If you could get me BPR's number, that would be great! They have a web site but it just says under construction with no contact information. Thanks ahead of time.
Old Sep 16, 2006 | 09:57 AM
I love twins!
Originally Posted by alwayssideways
Thanks for the info. I will have to check that out when I eventually get another day off.
Old Sep 16, 2006 | 10:03 AM
I love twins!
Yeah, it should be pulling engine codes with the stock ECU and all the mods. The check engine light is definitely on with the stock ECU and not the Pettit.
Old Sep 16, 2006 | 11:05 AM
Pobody's Nerfect
well, check the tps, i doubt it is that though. and that isnt how it is adjusted on the fd, it is different. there is an archived thread about it. so do you mean that the car seems to like die off above 3000 rpm? it could be limp mode with the stock computer. i have dealt with that on my car and it is no fun at all. pull the CEL code with the sotck computer and get back to us wiht the results.
Old Sep 16, 2006 | 11:54 AM
FDTT19's Avatar
hey, I let Jesse know about your thread but he doesn't have much time to get on here but said he would try. He said give him a call and he'll help you out.
Old Sep 20, 2006 | 10:35 AM
I love twins!
Still looking for BPR's number...........help!
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
