whats the cause of blown engine?
Old Sep 13, 2006 | 12:13 AM
Fc Spl's Avatar
Would boosting while the engine is sold make the engine blow? I would like to know the causes of a blown engine? this is coming from an engine that was recently rebuilded?
Old Sep 13, 2006 | 12:21 AM
snowball's Avatar
I live in the lounge...
yah you could do damage by boosting on a cold engine.
Old Sep 13, 2006 | 12:26 AM
RotaryEvolution's Avatar
Sharp Claws
cold engines usually tend to boost more so it could have overboosted with insufficient fuel for that boost level. also it is a good idea to allow the seals to fully warm up before beating on them.
Old Sep 13, 2006 | 02:00 AM
NOPR's Avatar
Rotary Apprentice
running the engine hard when cold is always bad, but a stock engine on stock boost shouldnt blow due to just being cold. in fact, theres a throttle body device that prevents you from truly going wide open throttle until the engine is warmed up.
Old Sep 13, 2006 | 02:12 AM
airworks-fc3s's Avatar
pistons go home!
first of all: is your ride stock? what type of 2nd gen?
it very much depends on your setup... but basically guys are right, boostin' cold engines is not good for their lifespan!
Old Sep 13, 2006 | 02:16 AM
rotarylove's Avatar
Newbie
ur seals might have been done for in the first place and is ur car a base model??? caz my cpu wont even let me boost
Old Sep 13, 2006 | 02:17 AM
NOPR's Avatar
Rotary Apprentice
what!?
Old Sep 13, 2006 | 02:18 AM
calrx7's Avatar
aim** JI II IM IM Y
its common sense to warm up any car b4 u drive hard right? another cause is over heating. apex seals are like the heat's bitch. bad injectors could blow engine too. GG
cdn
14
Sep 10, 2015 06:23 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
