Tire/rim width
Old Mar 3, 2001 | 08:28 PM
Sebring7's Avatar
Tire/rim width
I've seen this issue go by a few times, but I forgot :P
What's the widest you can go rim and tire width, in both the front and the back?
86' GXL (All parts from this car will be going to the SE)
Racing Beat Headers
Sebring Exhausts, with Y-Pipe
Blitz Intake
No A/C & P/S
16" SportComp Electric Fan
And all the suspension goodies...
86' SE in the works
So far I've bought Erebuni rear skirt, and side skirts. The GTU wing, and next to come is the Type II front airdam from Border. Going to paint it white, and slap on white ADR DTM wheels
Old Mar 3, 2001 | 08:31 PM
RETed's Avatar
8" front, 9" rear on stock fenders.
-Ted
Ted Koseki
Technical Advisor
http://www.k2rd.com/
Old Mar 3, 2001 | 08:33 PM
Sebring7's Avatar
So then that means in front I can go with 225, and 245 in rear? Please correct me, this will be my first time buying racing wheels.
Racing Beat Headers
Blitz Intake
No A/C & P/S
86' SE in the works
Old Mar 3, 2001 | 08:46 PM
RETed's Avatar
225 up front, and actually 255 in back.
I'm not too sure what you're eyeing...
Not all 225 wide tires will fit up front.&nbsp The offset of the rim is critical in making sure it fits.&nbsp There are some very "fat" 225 tires due to wider sidewall profiles (i.e. curb protection design).&nbsp +25mm offset on an 8" wide rim should fit up front - you might need to roll the fenders a bit for slight clearance problem, but this easily clear the inside shock.
Th rears can easily swallow a 255 wide tire.&nbsp You can run a 9" wide rim with a +30mm offset no problem.&nbsp Some people have even run wider 265's in back, but it gets kinda tight with anything over 255.
-Ted
Ted Koseki
Technical Advisor
Old Mar 3, 2001 | 08:54 PM
Sebring7's Avatar
Thanks
Old Mar 3, 2001 | 09:23 PM
BhamBill's Avatar
Hey Ted,
Do those numbers hold for both 15" and 16" wheels? My next move for autocross will be race rubber and I'd like to use 15's to keep the weight down. Thanks
Bill
88 GTU
Eibach Pro-Line Springs
KYB AGX Shocks
Old Mar 3, 2001 | 10:10 PM
RETed's Avatar
Yep, it doesn't matter.&nbsp Rim size basically is a matter of brake clearance.
-Ted
Ted Koseki
Technical Advisor
Old Mar 4, 2001 | 08:02 AM
1BADRX7's Avatar
I have used:
18x8.5 with 225/35/18 front
18x9.5 with 255/35/18 rear
I didn't have any problems running these size tires and rims, and I can actually put 265/35/18 in the rears with no problems. I also recall someone using a 10" rim on the rear of a TII without any problems as well.
Offset is the key!
Richard
NSXTASY
1BADRX7
Old Mar 5, 2001 | 08:57 AM
Sebring7's Avatar
I got in contact with the people I'll be buying my wheels from. Would a +38mm wheel offset fit fine in the rear with 245/45/17 tires, and 225/45/17 in front?
Old Mar 5, 2001 | 10:18 AM
go_speed_go's Avatar
I hate to throw this wrench out, but what kind of racing are you going to be doing?
Big diameter wheels means potentially same or taller gear ratios and more unsprung weight.
Old Mar 5, 2001 | 01:08 PM
For autocross, you'd be better off with 15 or 16 inch wheels. I run 15x7 wheels with 225/50-15 Kuhmo V700 R compound tires. With my springs and shocks, this setup is good for a little over 1.0 g's of lateral grip.
If you run 245's in the back and 225's in the front, you're gonna push/plow like crazy unless you've got some mad power and/or significant camber adjustments to help coax the rear around.
The 225/50-15 will also give you shorter gears and a slightly lower ride height.
If you haven't autocrossed much yet, don't even bother with R-compound tires until you've run several events. Not only are they sticky and expensive, but they're very easy to ruin/flat spot in a single day if you're not used to a lot of threshhold braking and cornering.
This is, of course, just my .02 on the matter.
Chris
'90 Sunrise Red 5 sp Convertible
- Bonez intake & Super-flo cat
- Drona-Max Cat-back
- MD Racing ECU - Autocross Package
- Tokiko 5 ways & Eibach Pros
Old Mar 5, 2001 | 02:01 PM
Sebring7's Avatar
I don't want to use these wheels for the racing though, just for looks and daily driving. I have 15x7 wheels on my current rx7 with 225 on both front and rear, i'm planning on using these for just autocrossing. I've never done auto-x before, so this'll be my first time. I just want these for style
Old Mar 5, 2001 | 05:43 PM
E6KT2's Avatar
Does this rule (225/255) change if you run coil-overs because you have more clearance inside the fenders? I want to run 245's up front!
Ephesian 4:1-7
Old Mar 5, 2001 | 07:38 PM
BhamBill's Avatar
go_speed_go - What offset are your 15X7's? I thought I'd use 7 or 7.5" wheels with the Kumhos too.
Bill
88 GTU
KYB AGX Shocks
Old Mar 5, 2001 | 08:14 PM
Jerk_Racer's Avatar
I knew of quite a few people back in Japan that ran with with 17x8 in the front and 17x9 in the rear. The common tire sizes they would use were 235/45R17 and 265/40R17 for the front and rear respectively. The fenders might have been rolled, I never checked, but they were normal fenders.
Old Mar 5, 2001 | 08:21 PM
Sebring7's Avatar
Ok, I know that for the stock wheels on the Turbo II, their offset is +40mm, so would 245/45 tires fit that 16x7 wheel with a +40mm offset?? If not, what can be done to make them fit?
Old Mar 5, 2001 | 09:08 PM
Jerk_Racer's Avatar
Oops, this was like a double post. My browser is kind of screwy.
[This message has been edited by Jerk_Racer (edited March 07, 2001).]
Old Mar 6, 2001 | 12:08 AM
Sebring7's Avatar
I want to auto-x
Racing Beat Headers
Blitz Intake
No A/C & P/S
86' SE in the works
Old Mar 6, 2001 | 12:49 AM
Flamin' NOS's Avatar
What's the widest meats that will fit on the stock TII wheels? Is it 255 or 245?
Old Mar 6, 2001 | 03:31 AM
RETed's Avatar
How wide of a rim?&nbsp 7" wide rim up front with that kinda offset will fit a 225 tire but NOT with a 7.5" or 8" or wider rim.
The rears are fine 8".
-Ted
Ted Koseki
Technical Advisor
Old Mar 6, 2001 | 03:33 AM
RETed's Avatar
No tire shop that has a sense of safety will mount a 255 wide tire on a 7" wide rim.&nbsp 245 tire on a 7" rim is iffy (not recommended) - a 245/45/16 tire will fit on a 16"x7" rim.&nbsp This will NOT fit up front and only in the rears...
-Ted
Ted Koseki
Technical Advisor
Old Mar 6, 2001 | 03:36 AM
RETed's Avatar
You cannot run 245's up front.&nbsp The limitation is the bottom perch of the MacPherson strut up front, so it has nothing to do with the coilovers.
-Ted
Ted Koseki
Technical Advisor
Old Mar 6, 2001 | 03:37 AM
RETed's Avatar
Only in the rear...
-Ted
Ted Koseki
Technical Advisor
Old Mar 6, 2001 | 09:18 AM
Sebring7's Avatar
Originally posted by RETed:
How wide of a rim? 7" wide rim up front with that kinda offset will fit a 225 tire but NOT with a 7.5" or 8" or wider rim.
-Ted
Cool, the ones I will be buying are 7" wide front and back..
