Color change on an LED screen
Old Feb 27, 2002 | 03:20 PM
BigRed's Avatar
I've got a Blitz Dual Turbo timer which when running has a green indiglo back lit display, but when the turbo timer has started it's countdown, it flashes from that back lit display to a red back lit display (also if you were to peak too high in the boost the red backlight would come on) is there a way to change the red back lit display to an always on mode? it would mesh so much better with the rest of the red lights in the interior.
Old Feb 27, 2002 | 09:32 PM
NickSimcheck's Avatar
My friend has that timer on his talon, i'll talk to him within the next few days and i'm sure he'll know if you can or not. i'll PM you with his email address if you wanna get ahold of him, i'm sure he won't mind. just tell him your a friend of Nick
Old Feb 27, 2002 | 10:20 PM
Node's Avatar
if you wanna get down and dirty you could unsolder all the LEDs and swap em. I bet they're very tiny (flat for PCB mounting, probly like what cellphones use)
This way it would always be red when green, and green when red.
Nothing like Voiding your Warranty
Old Feb 28, 2002 | 09:23 AM
BigRed's Avatar
I have yet to pull apart the unit. I was hoping that I could avoid that (ie, putting a load, or changing the voltage across one of the leads) but what node described sounds like the best bet.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
