Stored engine
Old Feb 27, 2002 | 01:09 PM
Mazdarules's Avatar
Stored engine
I might be picking up an 86 gxl (automatic, YUCK!) that has been sitting in a garage for two years. Does anyone know what the best way is to nurse it back to health. It has good compression, etc no engine problems.
I'm thinking, drain the fuel system, replace the pulsation dampners, new fuel filter, new plugs, wires, oil change, new o2 sensor, cooling system flush, new thermostat, replace hoses as needed, fresh atf in the tranny, new tranny filter, brake bleed and a light atf treatment before I try to fire it up. Is there anything else i should think about replacing?
Old Feb 27, 2002 | 01:11 PM
damn hippies
a rx that hasent been run for 2 years could be back, changing fluids may help but make sure it runs liek it should
Old Feb 27, 2002 | 01:13 PM
Mazdarules's Avatar
it's not starting right now, i believe it's flooded, also the battery is dead.
This means, I get it really cheap, 900 can, that's like 500 american
Old Feb 27, 2002 | 04:21 PM
Mazdarules's Avatar
any other things I should look at doing to it before I put it back on the road (if I buy it?)
Old Feb 27, 2002 | 05:03 PM
ZachSpazz's Avatar
I wish I had a posse...
A light MMO or ATF treatment left to sit for a few days is almost a requirement. When you get her started, it'll probably need a TPS and BAC tune up (my GXL stored for 6 months needed it). Make sure to drain that old fuel and run plenty of injector cleaner as well. When you run her, DO NOT take it above 3000 RPMs for about 100 miles.
Good luck!
Old Feb 27, 2002 | 10:06 PM
Mazdarules's Avatar
alright, thank you for you help zachspazz
Old Feb 28, 2002 | 05:30 AM
I wish I was driving!
Re: Stored engine
Sounds good, but seriously doubt the requirement for a new tranny filter. Those things are made of wire screen mesh, and basically only trap metal particles. never really need changing.
As you have already cranked tohe motor, it may be no good, but I recommend pulling the EGI fuse and turning her over until your register some oil pressure. Just a little safety thing I would do.
Sean
astrum
24
Nov 15, 2017 08:44 AM
thecody59
40
Aug 23, 2015 06:41 PM
Brice_Brice
Aug 18, 2015 10:42 AM
GrossPolluter
Aug 16, 2015 09:50 AM
