Relocating fuel filter, is this the place to put it?
I will be relocating the fuel filter because all of you know why. I was wondering where is the best place to put it? I was thinking the line marked "fuel" on top behind the UIM, this seems to be the easiest place to install it. Any other suggestions? .......Is this the line i want, it attaches to the backside of the TB?
No do not put it there. Here is the proper place to put it. Make sure you use high pressure fuel line designed for fuel injection. If you want to get fancy you can drill and tap the subframe and use the stock bracket to mount it.
Trending Topics
Do yourself a favor and buy a shop manual for your car . . . .
It's a good thing you asked the forum. That would have sucked. Rotary Experiment Seven did mine about 2 years ago and I'm very happy with my 5 minute fuel filter changes
I did a write up about this a couple years ago if you search. There isn't much to it except getting the stock filter out of its location which can be a pain. All you really do is replacew the hoses and extend them down through the openings of the subframe. Make sure you use the right hose and secure it so it doesn't rub on anything.
Check out this post, pictures at the end.
https://www.rx7club.com/showthread.p...3&page=1&pp=15
Terry7
Terry7
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
