which springs?
Old Sep 8, 2006 | 11:22 AM
RoughRex's Avatar
It's Radiation Therapy
which springs?
Guys...I just bought some Tokico HP's and I need some springs to go with them. I'd like something with a comfortable ride but of course I'd like SOME performance gain. Function is definately more important to me than looks so, while I'd like to drop the car a little...if it messes up the camber of the wheels its a no-go. I know I can get camber plates and a camber adjuster for the rear but, I'm not made of money here. Should I stick to stock height springs? If so, does anyone know where I can get some? all I can find are lowering springs.
Old Sep 8, 2006 | 12:34 PM
White94RX's Avatar
BMW Tech
Get Eibach springs. Just a little stiffer, drops about an inch. Just enough to notice and handle better, but it's not slammed. Eibach pro-kit is usually around $230-ish new.
Old Sep 8, 2006 | 03:52 PM
RoughRex's Avatar
Sounds good but will an inch effect my camber?...I don't buy cheap tires so, I don't want them wearing oddly and needing replacement prematurely.
Old Sep 8, 2006 | 04:05 PM
aznpoopy's Avatar
strike up the paean
yes
any drop = more toe in, more negative camber
the more drop the more alignment change
bottom line, get aligned after you change significant pieces of your suspension.
Old Sep 8, 2006 | 04:48 PM
RoughRex's Avatar
that's what I thought but, I've heard there's little or no adjustment to the rear camber without aftermarket parts. Is this true or am I mis-informed?
Old Sep 8, 2006 | 06:37 PM
aznpoopy's Avatar
strike up the paean
iirc... the FC has no *stock rear camber adjustment, unfortunately.
Old Sep 10, 2006 | 12:09 PM
RoughRex's Avatar
Allright so either have to pay an extra $130.00 for a rear camber adjuster or get some stock height springs...does anyone know where I can get some affordable springs that are stock height? Aside from stock springs of course.
Old Sep 10, 2006 | 02:27 PM
andrewb70's Avatar
If you have equal size tires front and back you can rotate them regularly to keep them from wearing funny. I am not aware of any springs that offer stock ride height with an increase in spring rate, aside from doing a Ground Control or other coilover kit that will allow you to adjust the ride height.
Andrew
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
inMotion719
Sep 28, 2015 03:09 PM
