just put my K&Ns in. what to do with AP?
Old Sep 5, 2006 | 08:03 PM
catch-22's Avatar
like the title says what sould i do with the airpump? right now i just have it disconnected and the holes pluged and yes it idles like crap but i dont want the moo sound! any suggestions. dont have a PFC.
Old Sep 5, 2006 | 08:13 PM
DaleClark's Avatar
RX-7 Bad Ass
First off, build one of my SUPER simple and SUPER cheap air pump anti-moos -
http://www.clubrx.org/default.asp?id...ntent=62&mnu=5
Get a small K&N filter for the airpump, place it up front where it can draw cool air and run a hose from the filter to the airpump. Putting the filter directly on the airpump can cause premature failure since it's pulling in VERY hot air right off the turbos.
Dale
MR2_spaceMONKEY's Avatar
buy a pfc and ditch it.
or do what dale said.
Old Sep 5, 2006 | 08:21 PM
catch-22's Avatar
will do.
Old Sep 5, 2006 | 08:59 PM
Get_SiDeWaYs's Avatar
ok lets say i do have a pfc. just ditch the air pump, block off all hoses and loose the cat? correct me if im wrong, i just like to plan out things b4 i rush into them
Old Sep 5, 2006 | 09:36 PM
ditch airpump. Get new pulleys and belt. block of hoses. Losing stock cat is good(period). From what I've read you may clog it up worst running with no airpump. If you ditch the cat for a midpipe be sure you can control boost spikes or creeping, as it seems very common with a full exhaust. Myself, I'm still running a hiflo cat. Will probably switch to a mp once I rebuild the engine, since it'll be convient to port the wastegate then. And lastly....
SEARCH
I'm no expert, so take this with a grain of salt.
Old Sep 6, 2006 | 11:50 AM
sevensheaven's Avatar
REPU Wanter
Blow up engine!.................................. Just kidding!
I couldn't resist adding to the list. :-)
I was going to recomend Dales web page, but he beat me to it.
Hey Dale,
when do you plan on adding more info / projects to your page?
FührerTüner
Sep 20, 2015 01:07 PM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
