this ok to use on the car?
Old Sep 1, 2006 | 12:57 AM
FD3S2005's Avatar
SideWayZ The Only Way
im just curious because i would like to clean the injectors and dont want to use somethign harmful on the car
sorry if its to small.. it was taken with my phone
Old Sep 1, 2006 | 01:24 AM
adrock3217's Avatar
Boost in..Apex seals out.
The only way to effectively clean your injectors is to pull them, and send them to a shop (Cruzin' Performance, for example). These..are not a good alternative.
Old Sep 1, 2006 | 08:47 AM
KYLiquid's Avatar
Oil Injection
the only fuel injector cleaner I have ever used is Redline Fuel Injector Cleaner, or Lucas Fuel system treatment.
I pulled the fuel rail and injectors off the car, set them in a tray, mixed 1 gallon of gas with 1 bottle of the cleaner (to make something like a 25:1 mix of cleaner to gas, and put that in the empty fuel tank....then I just cranked on the engine and the injectors spit out the cleaner....and it took about 30 secs. Seemed to work pretty good and only cost me 15 bucks and 1 hr of time.
abrock3217 is right though....if you really want your injectors clean, send them out to be cleaned and bench tested/balanced...make sure you change the fuel filter at the same time!
Other than that, just use a quality fuel...like chevron or shell (chevron is all I run).
Old Sep 1, 2006 | 08:55 AM
melicha8's Avatar
Mazdaspeeding
Take em out send em to get cleaned. Just from cleaning I gained nearly 100% of the factory flow rate. They give you test results when you get them back. Plus you may have particulates blocking your diffusers(little plastic inserts that go down the injector port)
Old Sep 1, 2006 | 12:52 PM
JConn2299's Avatar
reliable performance
I'll second that. Now there really is a difference in gasolines. That didn't used to be the case. Check out www.toptiergas.com to get an explanation.
Now that I'm using top tier gasolines I've stopped using fuel injector cleaners. I'm wary of having "too much of a good thing." But when I was using fuel injector cleaners I got the best results with BG44k.
Old Sep 1, 2006 | 02:48 PM
FD3S2005's Avatar
ok lets see.. is there a write up on how to pull the injectors and if i were to send them how long do they usually take? and how much?
Old Sep 1, 2006 | 03:08 PM
dgeesaman's Avatar
Witchhunter is around $15/ea and he turned mine around in a week, including the USPS Priority shipping both ways.
Just look up the links on doing the rats nest job - because you pretty much have to pull the UIM and all the other nasties to get enough room to pull the injectors.
1) There's nothing wrong with those pour-in injector cleaners, except that they aren't very effective. 2) Better is to take it to a shop that connects a flushing machine to your fuel lines and directly flushes the injectors from the inside - so you don't have to spend hours removing and installing the. 3) Best is the ultrasonic cleaning with flow testing and results.
Dave
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Junkee
Aug 15, 2015 01:57 PM
