Power FC Partial throttle causing rich AFR
Old Aug 30, 2006 | 10:54 AM
nicad2's Avatar
HC is too high
I have been logging/tuning AFR in the cruise region for a while now. Unfortunately, I have had trouble getting some cells lean enough, but I think I have discovered why!
I noticed it when trying to hold the car in just a few cells to get alot of samples. When I would close the throtttle partially to keep the RPMs down, the AFR would drop.
Conclusion: partially closing the throttle reduces the incoming air enough to change the AFR, but not enough to move the engine to a different cell. This seems obvious enough as you wouldn't try to log AFR during deceleration. However, it happens with a very slight reduction in throttle opening. So it seems the best way to avoid this is to log only accelerations. Don't bother trying to hold a particular rpm to get samples.
Another solution is the data log analyzer software I have developed It allows you to exclude samples that don't meet your criteria such as "water temp > 83C" or "duty cycle >0". It works great for most cases I have tried (cold engine, engine braking,etc), but my TPS is not able to distinguish this partially closed throttle case.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Monsterbox
Sep 11, 2015 03:29 PM
