no sark
Old Feb 26, 2002 | 12:31 AM
Angry no sark
what can cause both coils to go out and not work?? i got gas,compression, and im not getting spark when i try to take out a plug and bring it close to metal. neither coil packs works. so how can i trace that??
Old Feb 26, 2002 | 12:54 AM
hypntyz7's Avatar
Damn man, your **** has just went all to hell the last few days, huh? Maybe you need a break or something, it seems to be getting worse :-(
No spark, in most of my experience, has to do with a bad afm or bad connection to the afm. Could also be the engine fuse under the hood, 40A, or a small fuse inside. Unplug the afm, crank the car, and see if it sparks.
Old Feb 26, 2002 | 12:59 AM
cymfc3s's Avatar
I Raise Chickens
if one of the leading plugs is completely fouled and not firing, the other one will not fire either. To test and see if you getting any spark, you can either pull the spark plug out and re-connect the wire to and see if it fires. Or take out the CAS (just make sure to mark it) and spin the CAS. When you spin the CAS, the ecu thinks the motor is spinning and will provide spark.
Old Feb 26, 2002 | 01:07 AM
Scott 89t2's Avatar
SOLD THE RX-7!
hmm, I don't think my car has any "sark" either but it still runs
Old Feb 26, 2002 | 01:15 AM
cymfc3s's Avatar
I Raise Chickens
apparently the canadian cars didnt come with the sark option.
Old Feb 26, 2002 | 01:17 AM
Scott 89t2's Avatar
SOLD THE RX-7!
dam I guess the 1st owner used it all up
Old Feb 26, 2002 | 01:58 AM
Protege Menace's Avatar
Repost Police Capt.
Nice double THREAD how did you manage that one? you even spelled it differently on the duplicate one
Old Feb 26, 2002 | 08:23 AM
hah sorry guys for all this trouble. its just pissin me off. ok i need to know what is the AFM? and what is the CAS??
Old Feb 26, 2002 | 08:39 AM
J-Rat's Avatar
Alcohol Fueled!
AFM is the air flow meter, its located under your air filter in a silver box...CAS is the Crank Angle Sensor. As you are facing the motor its on the right hand side lower front. Looks similar to a distributor with no wires.
Old Feb 26, 2002 | 08:40 AM
J-Rat's Avatar
Alcohol Fueled!
And I dont know what "sark"......
