Need quick, easy info ASAP-Bellhousing bolts 87 T2
Old Aug 24, 2006 | 03:02 PM
Owen's Avatar
Does anyone know the length, pitch, size of the bolts that bolt up the 87 5sp tranny to an 87 T2 block? And the qty of bolts too.
Thanks
Owen
Old Aug 24, 2006 | 03:58 PM
Aaron Cake's Avatar
Engine, Not Motor
The Factory Service Manual in the FAQ has the number of bolts. There is a thread pitch topic in the Archives which contains the sizes.
Old Aug 24, 2006 | 08:29 PM
Kenteth's Avatar
Like Ghandi with a gun
I've spent as much money on bolts for my seven during the rebuild as I did new oil for it... :/
Old Aug 25, 2006 | 02:20 AM
john ward's Avatar
oi oi oi
mazdatrix has for around 4 dollars a piece
Old Aug 25, 2006 | 06:51 AM
My5ABaby's Avatar
Rotaries confuse me
https://www.rx7club.com/2nd-gen-archive-72/master-list-thread-sizes-2nd-gen-nuts-bolts-367392/
Enjoy the work I put into that.
Engine / Tranny Mounts:
(1) 14 mm head - Length = 145mm (5 5/8 in) (with head of bolt)135 mm (5 1/4 in) (from bottom of head of bolt to end of bolt). Nut on opposite end. FINE THREAD
(1) 14 mm head - Length = 100 mm (3 15/16 in) (with head of bolt) 90 mm (3 1/2 in) (from bottom of head of bolt to end of bolt). FINE THREAD
(2) 14 mm head - Length = 45 mm (1 3/4 in) (with head of bolt) 35 mm (1 3/8 in) (from bottom of head of bolt to end of bolt). FINE THREAD
(1) 14 mm head - Length = 40 mm (1 1/2 in) (with head of bolt) 30 mm (1 3/16 in) (from bottom of head of bolt to end of bolt). COURSE THREAD
Old Aug 25, 2006 | 08:22 AM
Kenteth's Avatar
Can you quantify "course"... "coarse" thread?
Old Aug 25, 2006 | 08:27 AM
My5ABaby's Avatar
Rotaries confuse me
Nevermind...
Old Aug 25, 2006 | 08:45 AM
Aaron Cake's Avatar
Engine, Not Motor
I believe that the course thread bolts are a 1.50 thread pitch (or 1.75) and the fine threads are 1.25 or 1.0. Seriously, a thread gauge is about $5 at the local hardware store and saves a lot of guesswork.
Old Aug 25, 2006 | 09:08 AM
Owen's Avatar
Thanks everyone!
If that link above had contained the words "bell" or "housing" I woulda found it...:-)
Old Aug 25, 2006 | 09:11 AM
My5ABaby's Avatar
Rotaries confuse me
ength, pitch, size
It contains those 3...
Old Aug 25, 2006 | 02:40 PM
Owen's Avatar
I only searched for bellhousing bolt length
FD3S_wanted
Sep 22, 2015 06:18 PM
