Sponsored by: CARiD
newbie with first newb problem
Old Aug 20, 2006 | 05:10 PM
SpooledupRacing's Avatar
on my 86' non turbo 5spd
a first problem (great here they come) lol
I got in the car put the key in turned the power on all the lights came on etc I turned the key and it went click all the power went away and nothing..
I waited a minuted did the same process over this time it started and ran fine... does this car have a main relay like hondas or maybe a bad battery etc?
what do u guys think is this a "rx7" issue
Dave
Old Aug 20, 2006 | 08:35 PM
Old Slow Coach's Avatar
Front Range Express
Dave, I'd try posting this question in the 2nd gen forum. If it is an "rx7" issue", it'll be 2nd gen related and not a general rotary tech issue. Sorry I don't have an answer to your question, but trying to help you find it!
Old Aug 20, 2006 | 09:23 PM
thank you.. I will do so if I have any other problems.. I have started it like 3 more times and no problems since then
Dave
Old Aug 20, 2006 | 10:51 PM
C. Ludwig's Avatar
www.lms-efi.com
Clean the battery cables and make sure they're tight. Make sure there isn't an open circuit in either of those main cables. Common problem with loose or corroded cables or in one that is damn near broken all the way through.
Old Aug 21, 2006 | 03:08 PM
I get this problem quite often you have to use a brush on the contacts to the flux capacito.... I mean battery cables and then tighten them down to contain the 1.21 jiga watts of electricity. I got 5 dinar that says your positive battery terminal is loose.
Old Aug 24, 2006 | 07:59 PM
Kentetsu's Avatar
I'll jump on the bad battery cable bandwagon too. Could be pos or neg though, either one. Clean the connections at both the battery and the starter and you should be good...
Old Aug 24, 2006 | 08:03 PM
the neg cable was almost off (put on shity) so I fixed it and the problem is not cured but it dont die really anymore but dont always jump to 3k when low sometimes it just starts and runs (idles) at 550-700rpm
Dave
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
